Finaly changed my injectors
Old Apr 14, 2007 | 03:25 AM
olds442/vette's Avatar
olds442/vette
Default Finaly changed my injectors
Well i finally changed the injectors on my 90 and wow what a difference i had three bad ones but i changed all eight and it runs good and suprisingly it only took me about 4 1/2 hrs and i changed out the originals with accels. But i still need to reset my timming and my plugs. can anyone tell me the correct steps on how to change my timming?
Old Apr 14, 2007 | 09:07 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Get motor to operating temp
disconnect EST wire at connector beside brake booster. single tan wire.
start motor, check and adjust timing 6*btdc
turn off motor and replace est wire
remove neg bat terminal(30 sec should be enough) to clear code 42
Old Apr 14, 2007 | 09:09 AM
JackDidley's Avatar
JackDidley
There is a tan wire with a black stripe that comes out by the brake booster/wiper motor area. Disconnect it. Start car. set timing to 6*. turn off car and reconnect the tan/black wire. Done.
86 got here first again.
Old Apr 14, 2007 | 10:36 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Don't forget to reset the TPS and IAC also... check and clean the TB... to complete the tune process... good luck
To Finaly changed my injectors
