clutch "broke"
Good Luck
1. Ram C4 Conversion Pressure Plate #401
2. Ram C4 Conversion disc # 309M
3. Howe Slip on TOB # 82876
4. AMS Stock thickness Billet Flywheel # MSSF350
I had it all balanced with the new SCAT crank last week and picked it all up last Friday.
When I measured the stack ups, the RAM slip on TOB that comes with their package, would not work on my car. I can figure out why but the RAM would have been too long by @ .045" and would not collapse far enough to work,
so I called Howe, spoke with them and picked up the TOB above. It is shorter than I need and comes with
.045" shims to make it "longer" if necessary.
Saturday I will put the engine back in and then hook it all up as much as I can,, but I should be on the road 1-week from Fri/Saturday.
I cant wait to put the Clutch issue to bed.
I think the normal stock varies by store, depending on the manager. I'll ask him next time I go in, because I think I bought about all they had and I'll be needing more eventually.
