oil pressure problem
Old Apr 16, 2007 | 12:53 PM
Kool88vette's Avatar
Kool88vette
Default oil pressure problem
My oil pressure has been all over the place lately. It drops to 0 when I floor it. It will jump from 30 to 60 and back down. I just started it and it said 0. I gave it a little gas and it went to 10. I shut it down. Any guesses as to what's wrong?
Old Apr 16, 2007 | 01:11 PM
hookedup's Avatar
hookedup
FRAM filter?
Old Apr 16, 2007 | 01:18 PM
bjankuski's Avatar
bjankuski
Oil pump pick-up fell off?
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Just a guess but it sounds like it could the sender or spurious voltages in the sender circuit. Never pass a chance to dis Fram.
Old Apr 16, 2007 | 06:00 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
No way to make a "guess" until you verify if you have a gauge or an engine problem. Hook up a mechanical gauge and verify that you actually have an oil pressure and not a gauge problem. If it's an oil pressure problem, the first thing I'd check would be a filter obstruction. Not likely but possible. Next drop the pan and I would expect there to be a good chance of debris in the pick-up screen.
Old Apr 16, 2007 | 06:34 PM
CFI-EFI's Avatar
CFI-EFI
Before you do anything else, verify the conditions with a mechanical gauge.
RACE ON!!!
Old Apr 16, 2007 | 09:29 PM
nitecruizer's Avatar
nitecruizer
SMART ADVICE!!!!!
CRUIZER
Old Apr 16, 2007 | 10:43 PM
Kool88vette
my guess would be there is oil pressure. The gauge has been eratic for awhile. I have noticed that when I drive it hard the gromet in the drivers side valve cover comes loose and a litlle oil will shoot on the valve covers. I guess oil is getting to the top of the engine. How do I check for oil pressure? Where is the sending unit? It's not a Fram it's a Napa.
Old Apr 16, 2007 | 10:45 PM
Kool88vette
RACE ON!!!
OK, How do I do that?
Old Apr 16, 2007 | 11:14 PM
Kool88vette
I just started it again. The oil pressure went right to 20 and held steady. I took it for a ride, it was reading nomal oil pressure. A couple of times it went wild with numbers jumping between 0 and 65. This happened after I let off the gas. I think it's the sensor. I ordered one from Eckler's.
Old Apr 17, 2007 | 09:24 AM
Slalom4me's Avatar
Slalom4me
To verify the reading of an oil pressure sensor/gauge, one practice is
to attach a mechanically activated gauge that is known to be good.
My vote is that if the car can be raised, the port above the oil filter
(where the temperature sensor is) is easier to access for testing than
the port for the pressure sensor.
The OEM pressure sensor is mounted at the back of the engine. There is a
fitting that rises up from the rear of the block just to the left (driver's)
side of the distributor. The sensor threads into this. On my '89, there
is one dual-function sensor assembly - some other years have two single-function
units.
In my case, the distributor was removed for better access to the
pressure sensor fitting. Replacement fittings are difficult to obtain if
the existing one is damaged.
Old Apr 17, 2007 | 10:00 AM
Kool88vette
units.
Thanks, my Vette is a 88 so I'm sure it's the same as yours. I don't have a lift so I'll just change it. Thanks
Old Apr 17, 2007 | 10:14 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
If you don't mind waiting for your part to come from Eckler's that's fine but you could have went to NAPA, got the part and had it installed today. Just because you have a Corvette it doesn't mean you have to buy everything from a Corvette parts supplier. Not knocking Eckler's, just making a point.
Old Apr 17, 2007 | 10:23 AM
Kool88vette
I thought of that after I ordered it. Napa is usually cheaper too.
Old Apr 17, 2007 | 12:02 PM
CFI-EFI's Avatar
CFI-EFI
The year doesn't matter. All the L98s are as he described. You simply connect the hose of the mechanical gauge to the engine and read. The Corvette oil pressure sending units are not Corvette exclusive parts. As are many Corvette parts, they are used throughout the GM line.
RACE ON!!!
To oil pressure problem
