OPTI - MSD or Dyna?
Old Apr 18, 2007 | 01:42 PM
Rex Ruby's Avatar
Rex Ruby
Philly 'Burbs Events Coordinator
Default OPTI - MSD or Dyna?
I've been battling poor drivability since last year.
http://forums.corvetteforum.com/show....php?t=1574890
I done a few things with no real fix. Took it to my mechanic today and he says its the opti. Now I'm pissed as it only has 30K on it since I did it 4.5 years ago. Seems it should last longer, I replaced the orig at 86K and it wasn't bad the water pump was, I just did the opti then for reliability.
When my mechanic called around for some pricing he was told that there have been some problems with some of the new OEM units. Since the opti is not as accessable as say a slave cylinder and since the slave cylinder BS proved to me that just because it's new in box doesn't mean it's a good unit I want to get one that should last.
Should I go with the Dyna or the MSD, opinions please
Thanks in advance,
Rex
Old Apr 18, 2007 | 01:46 PM
Rex Ruby's Avatar
Rex Ruby
oh yea, best price and place to buy?
Old Apr 18, 2007 | 02:27 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Contact tjwong on the MSD. Last I checked he had the best price.
Old Apr 18, 2007 | 07:49 PM
zr2tim's Avatar
zr2tim
Rex,
I put in a Dyna-spark in my '93 a little under 18k. Not many miles since, but it seems tougher than the OEM. Hard to quantify.
What I liked most vs. OEM, was the cross ventalation. The Dyna comes w/ everything you need to plumb into the vacuum circuit and into the intake tunnel to grab the fresh air. Looks normal too, not added on, except for the line pulling in the air, but only a hardcore vette guy will notice.
My old OEM unit was pretty scuzzy inside due to no air flow, which no doubt killed it (rusty and all).
JMHO
Old Apr 18, 2007 | 11:02 PM
SJW's Avatar
SJW
The DynaSpark has been around longer, and has a good record in the field. I installed one on my '94 a few years ago, and it's been great. They sell direct. Last I heard, they were selling for around $600, but check that. Competition from MSD might have pushed their price down by now.
The MSD appears to be gaining traction in the marketplace. Last I heard, it was selling for around $500, but check that, too.
You'd almost surely be better of with either the Dyna or the MSD rather than the OEM Gen1 unit.
Be well,
SJW
Old Apr 18, 2007 | 11:12 PM
shop14's Avatar
shop14
summit racing has an axcel for $300,been running it for 2 yrs ,no problems
Old Apr 18, 2007 | 11:25 PM
Rex Ruby's Avatar
Rex Ruby
Originally Posted by zr2tim
Rex,
JMHO
agreed, the Dyna looks like an HQ unit. Only concern with it is servicing it ie, replacing the cap.
Be well,
SJW
Your pretty accurate on the prices
THe accel is only offered for Gen2
Old Apr 18, 2007 | 11:42 PM
dizwiz24's Avatar
dizwiz24
Thanks in advance,
Rex
I dont have either, but it seems to me the dynaspark is your better choice.
I can attest to some major issues with MSD products. Specifically Digital 6 plus ignition boxes that failed after 20-30 miles (3 in a row actually) and also brand new MSD 8.5mm wires that spark arc'd against the water pump housing.
Old Apr 19, 2007 | 02:31 AM
meffordg's Avatar
meffordg
I installed the MSD about 6 weeks ago. I liked the quality of the MSD unit, and so far have had no problems...but we are only talking a couple of hundred miles. The one thing I did make a mistake on was ensuring the cap was on completly. The o-ring seal is pretty thick and the torex screws can be a pain in the *** to tighten down with the simple tool they provide. IMHO no a reason not to buy.
Old Apr 19, 2007 | 12:09 PM
CAJUN C4's Avatar
CAJUN C4
Anyone consider the Delteq-DLT1011 ?
www.delteq.com
Old Apr 19, 2007 | 12:18 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
If cost is no object, go with the Dynaspark.
If you're a little more budget-minded, do the MSD.
Of the two, my nod goes to the Dynaspark, but both units are superior to the O.E.M. AC/Delco Optis.
Old Apr 19, 2007 | 12:20 PM
Rex Ruby's Avatar
Rex Ruby
www.delteq.com
That doesn't fully replace the opti, you still need a functioning opti with the Delteq set up. I was considering the Delteq but buying that and an Opti was a little to much on the wallet at this time
Old Apr 19, 2007 | 03:16 PM
Rex Ruby's Avatar
Rex Ruby
I decided on the MSD. Main reason was with the Dyna you have to uninstall it and send it back if you ever want to put a new cap on.
I'll let you all know how it goes, going out to the garage now to tear things down, part will be in at 11AM tomorrow and am planning on having things all back together mid afternoon. Alos I am going to replace the coil with an MSD unit.
Thanks for all the input
Old Apr 19, 2007 | 04:02 PM
Ruby6spd's Avatar
Ruby6spd
Active Streak: 90 Days
Hey John,
Let me know how it goes. I am about to take the front of my motor apart and was going to do an upgrade to the opti while in there. Since my opti is still fine with only 5k miles it will probably make sense to look into the delteq and go that route.
I think Frank (mr mojo) runs this in one of his cars and likes from what I can remember
Old Apr 20, 2007 | 07:37 PM
Rex Ruby's Avatar
Rex Ruby
***** Fu*ker replacing the opti did not fix my problem fu******K.
Anyone want to buy a Ruby?
Old Apr 20, 2007 | 09:05 PM
bogus's Avatar
bogus
how many miles on this engine???
Old Apr 20, 2007 | 09:15 PM
Rex Ruby's Avatar
Rex Ruby
116K
To OPTI - MSD or Dyna?
Old Apr 20, 2007 | 11:17 PM
tobijohn's Avatar
tobijohn
Bench Racer
St. Jude '03 thru 14,'25
Well that sure blows. Why exactly was your mechanic so sure it was the opti?
Old Apr 20, 2007 | 11:57 PM
bogus's Avatar
bogus
116K
here is my thinking... if the cam is wearing, or if a valve is a little burned, it will cause a misfire.
I would do a leak down test... check if there is a pressure loss.
Old Apr 21, 2007 | 07:16 AM
Rex Ruby's Avatar
Rex Ruby
He thought it was in the ignition based on test driving it.
Guess that is next.
Here is what I am thinking,
Maybe the fuel pump is going or maybe it's the computer
