Iginition Timing 89 Corvette
Old Apr 22, 2007 | 09:50 AM
berry72's Avatar
berry72
Cruising
Default Iginition Timing 89 Corvette
I have been trying to locate the plug for the EST. Under the hood tells me that the wire is a tan closed single wire with a black strip. I have searched high and low and still no plug?? Any help is much appreciated!
Also - one other issue / I am trying to run down a vacuum schematic - same issue under hood doesn't show the full picture. The vacuum hose running from the EGR selnoid goes directly to the EGR valve which makes sense to me but should same hose also go directly to the fuel pressure regulator? There are 2 vacuum hook ups on the passenger side of the plenum - one goes to HVAC and the other to the fuel pressure regulator - not sure if that is correct? Does anyone out there have 89 corvette that cold look at and give the answeres I need?
Old Apr 22, 2007 | 10:43 AM
cv67's Avatar
cv67
St. Jude Donor '05
EST wire-look around the distributor/master cylinder area near the firewall. May have to dig through the harness to find it though.
Old Apr 22, 2007 | 12:43 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
EST: Check in the wire bundle/wrap around where cuininartvette said, sometimes its in the wire bundle.
Vacume: Use the search function and include archives in the search...
Old Apr 22, 2007 | 04:05 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The vac line from the EGR sol goes to a T and into the fitting under the TB.
The AFPR connects directly to the vac fitting on the RH side of the plenum rear. On earlier C4s there might be a T going to the AIR diverter valves.
Old Apr 22, 2007 | 07:53 PM
Slalom4me's Avatar
Slalom4me
You've received several posts with help for location the EST connector
Here are photos 86Pacer contributed in 'whats the EST and where is it'
Tan wire w/ Black stripe
Old Apr 23, 2007 | 04:45 PM
berry72's Avatar
berry72
Cruising
I found it and I've got the timing adjusted. The car runs pretty good but surges when idling and also when driving along and not touching the gas the engine will idle up and then back down. I believe I have a vacuum hose hooked up wrong. I followed the diagram under the hood but something still seems to be causing the car to backfire every once in a while - not bad but nevertheless something isn't right. Any suggestions?
Thanks to all for your help!
Old Apr 24, 2007 | 10:03 AM
berry72's Avatar
berry72
Cruising
I got it - thanks to all...!!!
I found the vacuum leak by blowing smoke into the intake which was an idea given to me on another thread I had open!
This place is great! Thanks to all...!!!!!
Old Apr 24, 2007 | 10:40 AM
sami85L98's Avatar
sami85L98
Cool, glad worked out for ya, smoke detector machines are the best to use for detectin vacum leaks, i did at my mech place, it was a such tiny spot i would have never detect with water or any spray kind. No enjoy.
Old Apr 24, 2007 | 12:49 PM
RRT vette's Avatar
RRT vette
To Iginition Timing 89 Corvette
