Dougnash 4+3 Question
Old Apr 23, 2007 | 08:53 PM
Repzard's Avatar
Repzard
Default Dougnash 4+3 Question
I heard that the 4+3 has a fuse some where can someone tell me where it is located in the fuse box or is it not in the fuse box but under the hood some where( id like to check it and see if it is blown.
I looked in my helms and dont see anything about a fuse for the OD unit listed unless i over looked it in the helms.
Or if someone can give me the page number it is located on.
Thanks forum
Repzard
Old Apr 23, 2007 | 09:45 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
It's on the guages fuse, right side of dash.
Another forum member had the fuse keep blowing when he hit the overdrive switch, and the overdrive light wouldn't come on. It ended up being an electrical connector fell off of the pressure switch in the pan and touching the case. Using the switch sent 12V to it and caused a short.
Old Apr 24, 2007 | 07:05 PM
williammackean's Avatar
williammackean
St. Jude Donor '07
Pics of inside OD Unit.
You can see the connectors. Don't forget your synthetic ATF fluid, filter (Ford part), and do NOT use form-a-gasket! I just dug that crud out of my unit. Not fun.
To Dougnash 4+3 Question
