Rocker Adjustments
Old Apr 27, 2007 | 01:30 AM
aklita's Avatar
aklita
Default Rocker Adjustments
Hi all
I have just changed my valve seals and replaced the rockers. The Haynes Manuals recommends adjusting rockers when the piston is TDC until the push rod can no longer be turned by hand then a futher full turn of the rocker nut. I am a little concerned that this may overtighten the rockers and cause damage. I have read were only a 1/4 or 1/2 addition turn is all that is necessary. Its a standard 85 Vet.
Any suggestions?
Andy
Old Apr 27, 2007 | 01:38 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
1st: Get a FSM (helms) and use the haynes for a door stop.
2nd: Rockers and adjustments are covered in prior posts many times over, use the search function and your'll get more info than you can imagine...
Old Apr 27, 2007 | 01:44 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
A fail-safe method is EO/IC:
-select a cylinder
-turn the crank till the Exh valve just starts to open and adjust the Int valve
-turn the crank till the Int valve starts to close and adjust the Exh valve
I set zero lash by twirling the PR and adjusting the rocker nut till I just feel drag. Then I give the nut 5/8 turn more and lock the position. This puts the preload between 1/2 & 3/4 turn past zero lash.
Old Apr 27, 2007 | 01:47 AM
Carpenter's Avatar
Carpenter
I agree with Vinnie, do a search if you like reading rather than doing. (Sorry Vinnie, couldn't resist)
However, If i were you I'd 'aproximate' the correct lash then fire it up and adjust all rockers by 'ear'. Then while running I'd 'tighten' each rocker 1/2 turn (exactly) and set your lock.
THEN I'd install the covers and worry about the oil mess.
OR....you can READ how to do it.
Old Apr 27, 2007 | 02:14 AM
cv67's Avatar
cv67
St. Jude Donor '05
that pushrod will keep spinning as you crank it down so I wouldnt go that route....I take the up/down slack out of them and then go 1/2-3/4 turn or so and see where youre at.
This place is your online manual.
Old Apr 27, 2007 | 02:16 AM
STL94LT1's Avatar
STL94LT1
Old Apr 27, 2007 | 02:36 AM
65Z01's Avatar
65Z01
I've found that the difference between just beginning to feel a little drag on the PR and it being hard to twirl is about 1/8 turn. That's why I chose 5/8 turn as the set.
This technique requires a sense of touch but it's easy to develope.
Old Apr 27, 2007 | 02:50 AM
Carpenter's Avatar
Carpenter
I'm 'old school' I guess. I just gotta do it while running, oil mess and all.
Old Apr 27, 2007 | 06:29 AM
65Z01's Avatar
65Z01
I saw a mechanic friend of mine bend pieces of cardboard over the PRs of a 4-banger rice-burner to set valve lash and there was no oil spill nor spray, though I don't know how that technique would work on our SBCs??
Old Apr 27, 2007 | 07:40 AM
silver86's Avatar
silver86
I just set the lash on my new pushrods. The method I used:
1. When the exhaust valve starts to open, set the intake vavle
2. When the intake valve is approx. 3/4 closed, set the exhaust
I tightened until there was no up and down movement, and added 1/2 turn and set the locks.
I tightened my original rockers while she was running...I cut a small strip of cardboard to deflect any oil from getting on the headers. There really wasn't much of a mess at all. But the exhaust was so loud that I had a hard time locating those that needed the lash adjusted.
Old Apr 27, 2007 | 09:01 AM
Sam Lam's Avatar
Sam Lam
NAPA sells some little spring clips that prevent the oil from squirting out of the rocker arms. They cost about $6.00.
Just curious as to why the 5/8 turn is used when the FSM indicates one full turn beyone the zero lash. Trying to learn something here!
Old Apr 27, 2007 | 09:59 AM
SEA4's Avatar
SEA4
I just picked up a set of 16 of those little clips you mentioned..
I should be firing up my project on Saturday and will be adjusting my valves while the car is running.. seems like the best way to do it.
You can set by the book without the car running, but if the lifters have collapsed a little, whats the point?
I learned a valuable lesson while doing my intake gaskets (and a million other things 'while I was in there') when I tightened my rockers to get rid of the play they had.. none took more than 1/2 turn.. but then, the next day, they had play again.
I'm backing them all off 1 full turn then once the car is running with the clips in place I'll back them off more if needed to get each one clacking.. then I'll tighten from there.
Can't see how that method wouldn't work the best.. and with the clips stopping the oil spray, seems like the way to go.
Old Apr 27, 2007 | 10:34 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Over the years, I've seen everything from 1/4 turn to 1 turn recommended for hydraulic lifters in SBC's. (I know; it's a geometry thing...)
Best advice I could give: Go by the manual for YOUR car.
Larry
code5coupe
__________
i ain't easily impressed....
Old Apr 27, 2007 | 11:18 AM
rick lambert's Avatar
rick lambert
I'm also of the old school, and I've used the little clips for years. with vinnies87..do a search, and you'll learn how to basically adjust all lifters CLOSE before starting the engine. One of the main things you don't want to do is over tighten them..that can cause engine damage. The reason guys have found a difference on how far they need to adjust is simple, maintainance...even though we're talking same basic 350 some engines will experience more wear on the valve train (ie. cam, lifters,rockers) if they've been somewhat neglected....prolonged oil changes etc.So, just don't over tighten.
Before I get flamed, thought I better add, other than maintenance, mileage and how hard an engine has been beat also contribute to wear.
Old Apr 27, 2007 | 11:25 AM
rocco16's Avatar
rocco16
Good advice; better way too loose than a little too tight.
Larry
code5coupe
__________
I ain't easily impressed....
Old Apr 27, 2007 | 04:27 PM
DVNCI's Avatar
DVNCI
Man I didnt' know about these - gotta get some today.
I've never done the running adjustment but had bought some cheap valve covers and was gonna modify em' to try the running method but I'm gonna get some of these!
This place is great . . . .
Old Apr 27, 2007 | 08:10 PM
aklita's Avatar
aklita
Default Thanks
Thanks for all the advice
I'll let you know how I go
Andy
To Rocker Adjustments
Old Apr 27, 2007 | 09:12 PM
Demonic85's Avatar
Demonic85
Here's the safest advice, pay a reliable mechanic to do it. I've tried to do it myself probaby 40-50 times with unsatisfactory results. I've tried using special tools to find TDC and they just dont work on an L98. So I think the best thing to do is pay the mechanic to do it or if your lucky enough, maybe he'll show you how.
Old Apr 27, 2007 | 09:37 PM
cv67's Avatar
cv67
St. Jude Donor '05
Theres a $6 tool called a TDC stopper you can screw in the spark plug hole to find TDC.
Old Apr 27, 2007 | 09:46 PM
Demonic85's Avatar
Demonic85
Yeah thats the one I bought. It doesnt work on an L98 due to the angle of the heads or some crap.
