low coolent temp
Old May 1, 2007 | 08:49 PM
Bullyj's Avatar
Bullyj
Guys,
Thefan comes on like it should after I replaced the fan motor, the fan relay and the relay connector but at the dash It always says low coolent temp.
Thanks in advance,
Bill
Old May 2, 2007 | 11:20 AM
MorpheusGPR's Avatar
MorpheusGPR
Similar to my issue. The car is suppose to have an overheating problem but the gauge always says low. I have a new wire connector for the aux. fan switch waiting for me to install. I also have to get the wires for the fans hooked back up as the previous owner grounded them.
I will be putting in a new switch for the gauge hoping to solve the problem. I am going to try and get some rtv around the wire where I can see the insulation has worn off and then get wire loom on it too.
Old May 2, 2007 | 03:15 PM
Jims1988C4's Avatar
Jims1988C4
Originally Posted by Bullyj
I replaced the temp sending unit and my readout still says low coolent temp any Ideas?
I have the same problem in my 88,I just replaced the sensor and its fine now. I also flushed my coolent and burpped it when it was cooler,no more low temp...
