low coolent temp
The dash gauge for temp coolant will read LO all the time if the temp sender is open circuit (check the sender with an ohmeter) or if the green wire that goes to the sender is open circuit somewhere up to the cluster connector. You can test if the wire is open by grounding the green wire and turning the ign sw to run. Your dash temp gauge should read 330 F if the green wire is ok to the cluster.
-cooling fan temp sw = RH rear of engine, near the oil dip stick
-ECM coolant temp sensor = front of engine below TB
Is there a sensor in the block below #1 & #3 spark plugs, with a Grn wire? If so check the connection to that senaor.
RACE ON!!!
BTW, I agree that you need to pick up a HELM FSM for your car. My '85 FSM is three times the thickness of the Haynes which covers all C4s, says a lot doesn't it.
??? - Did you rewire it or something? The CTS signal is used by the ECM to drive the Main Fan Relay when the a/c is off. Otherwise, with the a/c on, Fan Switch on the High Pressure Line opens at about 220 -230 psi causing the signal voltage at the ECM to rise to whatever the voltage potential is. With that, it grounds or drives the Relay. Section 6E and 8A should outline it for you. Head switch is used for Aux Fan only and if the Cooling System is the way it left the Factory, it will rarely if ever reach the threshold for operation.
So there is an apparent redundancy in the '85 as on pp 126 of the Electrical Diagnostic section is shown the Coolant Fan Temp Switch, which "also" controls the main cooling fan...hmmm, interesting.
Then on pp 124 is shown that the Aux Cooling Fan Temp. Switch (RH rear of engine) controls only the Booster Fan, while only the ECM controls the main fan.
So his main fan control depends on if he has the Booster Fan option.
In any case, on pp 6E3-9 is shown the "Engine temp sensor (gauge, overheat)" in the LH side of the engine...
BTW, thanks for the reference into the FSM text body...
RACE ON!!!
Are you working on a C4??
