i have a 94 lt1 after running for a while and the engine gets hot it will surge up and down between 500-1500 rpms and will accelerate very rough. it also used a tank of gas in only 220 miles all highway any ideas?
i have exactly this problem on my 94 too. so far, i've replaced the egr and iac with no change. the ses light has never come on, but i'll try to check codes this weekend on it. will there be a code and ses for a bad tps or o2 sensor?
i also have a 96 that i can swap parts off of to test. is the tps the same part on both model years?
regards,
charlie
cave creek, az
i found a crack in the rubber hose adapter on the tube that goes from the throttle body to the top of the fuel rail cover on the right hand side of the motor under the plastic shield.
replaced that and the problem went away.
regards,
charlie
cave creek, az
