89 vette not starting
Old Sep 4, 2007 | 07:00 PM
jfreak's Avatar
jfreak
Default 89 vette not starting
Hey, I'm having trouble with my 89. It won't start or even click when you turn the key. All the lights and gauges turn on but I cant get the thing started.
It ran fine till I filled it with gas, may be key trouble or clutch sensor not working. Any advice?
Old Sep 4, 2007 | 07:10 PM
engle1147's Avatar
engle1147
A bad/failing clutch switch would do this......bounce the pedal or replace it.
A problematic VATS would also do this. I'd try the clutch switch fix first 'cause VATS sucks.
Old Sep 4, 2007 | 08:17 PM
Arrest Me Red's Avatar
Arrest Me Red
Sounds like it isn't turning over, with no starter solenoid click audible. If this is the case, how old is your battery? Check battery terminals for corrosion. Lights will often work with a weak battery or corroded terminals. Good luck
Old Sep 4, 2007 | 11:20 PM
jfreak's Avatar
jfreak
Sorry I'm new to the forum.
I tried a little trick on the clutch switch and still didn't work.
I'm working on the VATS but haven't got to it yet.
Old Sep 4, 2007 | 11:23 PM
jfreak's Avatar
jfreak
No it's not turning over and there is no audible solenoid click either.
Thee battery is just over a year old and the terminals are in good shape.
I'll double check though.
Old Sep 5, 2007 | 09:50 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Has a code 46 been stored ??http://members.shaw.ca/corvette86/Code%2046.pdf
Vats..... http://members.shaw.ca/dankai/Vats%20Electrical.pdf
Old Sep 5, 2007 | 11:45 AM
jfreak's Avatar
jfreak
Originally Posted by AGENT 86
There must be. I checked the ECM and it's doing fine. I'm working on replacing the VATS right now. We'll see if that helps.
Old Sep 5, 2007 | 02:12 PM
RRT vette's Avatar
RRT vette
http://vatssucks.com/
To 89 vette not starting
