ABS fuse?
Old May 2, 2007 | 08:49 PM
Jared1984's Avatar
Jared1984
Default ABS fuse?
I need to know if there is a fuse for the ABS or if there is anyway to bypass (or disconnect) the ABS system on my 89
Old Aug 3, 2007 | 07:27 AM
86PACER's Avatar
86PACER
The ABS uses several fuses. They are the BRAKE fuse, GUAGES fuse, STOP-HAZ fuse, and INJ-1 fuse.
If you want to disable your ABS, go into the ABS compartment that is behind the driver's seat, under the rear cargo area. Then unplug the main wire harness from the ABS computer. The connector has a clip and a small flat head screw that needs removed.
Don't just pull the fuses mentioned above, as they are also tied into other circuits of the car that power other things.
