91 Brake Data
Old May 11, 2007 | 03:23 PM
jshyman's Avatar
jshyman
Default 91 Brake Data
I have had the 91 for two years now. The brakes worked, but not so good. I need to pump them once or twice and then I had quality braking. I sort info on the forum and the majority opinion was either adjust the brake push rod or I had air in the lines. I was told it is very difficult to bleed the brakes. Over the years I adjusted and adjusted; I bleed and bleed, but nothing changed. I decided to take the risk of wasting money and replace the master cylinder. NOW I HAVE BRAKES. It was very easy to replace. I guess I never connected the need to pump the brakes and a MC problem. But, you cannot argue with success. I hope this helps, I have seen many a post about brake problems.
