x or true dual
Old May 12, 2007 | 02:01 AM
MexCareBear's Avatar
MexCareBear
Default x or true dual
well i have magnaflows on my 96 lt1 and it sounds great..i would like alittle louder...and it sounds alittle to hallow..plus i just got them on today an the guy that installed them said give it a week or so to break them in...but i was guessing...should i go with x pipe or true dual exhaust...the guy said if i go with true dual it will be louder then it is now...an if i go wit x pipe it will give me low end torque an even the sound out...but he says the resionater already basically is an x pipe he said...kinda going crazy here thinking
Old May 12, 2007 | 02:06 AM
Demonic85's Avatar
Demonic85
I'd go with true duals, just my personal preference.
Old May 12, 2007 | 02:15 AM
bogus's Avatar
bogus
the resonator is sorta an x-pipe. but a true xpipe will make it louder over the sound of the resonator.
but be careful, ok? if it gets too loud, the local cops will be hearing you... and that equals tickets. not everyone is as lucky as I was and worked for the cops...
on other thing, noise does not automatically = fast. The Audi R10 Diesel is the quietest race car on earth, will kick most any other sports racers ***... without making a sound.
oh, finally, the C4 cabin does not like noise. it will sound great outside, but drive down the highway, and the resonance and drone will kill you.
Old May 12, 2007 | 02:27 AM
Demonic85's Avatar
Demonic85
Old May 12, 2007 | 09:14 AM
Black94Coupe's Avatar
Black94Coupe
That is, only if you dont like resonance and drone. To me, it really doesnt bother me because I usually dont have anyone else in the car with me, and when I do, we dont talk that much. But, I am young so I can do these sorts of things and not care. I guess when I get older I will think the same way .
Matt
Old May 12, 2007 | 09:21 AM
cv67's Avatar
cv67
St. Jude Donor '05
w/bogus
Old May 12, 2007 | 09:47 AM
MR NICE's Avatar
MR NICE
How would Headers,no cats, Lt1 mufflers sound?Anyone ever run this combo?
Old May 12, 2007 | 10:00 AM
fc_soldier's Avatar
fc_soldier
Thats hp music
Old May 12, 2007 | 10:12 AM
BerniesVette's Avatar
BerniesVette
A cut-a-way of a resonator for the LT1 shown on an earlier thread shows that it is not an "X" pipe. The internal pipes in the resonator go straight from one end to the other and do not mix the exhaust gases. I am installing an x pipe from magnaflo to replace my resonator. Hopefully it will give a little better sound along with a little more low end torque.
Bernie
Old May 12, 2007 | 10:55 AM
jimmers's Avatar
jimmers
I'd go true duals.
Old May 12, 2007 | 11:07 AM
N.C. Kid's Avatar
N.C. Kid
My preference also.
Old May 12, 2007 | 11:23 AM
MexCareBear
thanks for everyones opinions...ment alot....well when i went to the muffler shop he said taken the resionater off would be pointless cause it acts like an x pipe...but i told him it goes straight thru and he said no...but i was the one that seen the pic lol..hmm this is tough for me...any one have video clips of these set ups?
Old May 12, 2007 | 11:41 AM
lt4obsesses's Avatar
lt4obsesses
I am trying to replace my resonator with a Magnaflow dual in dual out. pn/ 12469. It looks like a pretty good fit. I've heard that it also has an internal x-pipe design. But there is a crossover pipe in the rear of the exhaust system. Either way in a '96, and some one correct me if I'm wrong, but the the system is already true dual. The pic I saw of a resonator cut open showed the piped going in a little bit and the middle was just empty space. I am thinking that the Magnaflow will increase flow alot and reduce that hollow noise from the empty resonator. Ihad a Magnaflow on a Camaro and loved it. i agree that louder is not faster, so it's a matter of personal taste. Your money, your car, right?
btw the Magnaflow mentioned is 3" 5"x8" with 4" center to center on inlet/outlets. Pretty close to the resonator only flows through. Crossovers or x-pipes are the norm in dual systems. In a non dual system, the exhaust manifolds run into a y-pipe, the exhaust then flows in one pipe down the chassis, goes into a single inlet, dual outlet muffler. Or into seperate pipes into dual mufflers. The point is that the exhaust travels through one pipe. The LT1 exhaust is considered a dual exhaust.
Old May 12, 2007 | 12:03 PM
Demonic85's Avatar
Demonic85
Its a lot cheaper/easier to go with true dual than putting an x pipe in there, like $70-$100. Not much more but some people might care.
Old May 12, 2007 | 12:57 PM
Aardwolf's Avatar
Aardwolf
You already have true dual, for the resonator, just put an x-pipe in there. That should make it louder, or muffler elims. The true dual systems I have seen would flow less then stock, they are small dia. and not mandrel bent. Yours is 2.75" dia. pipe if I remember right, most dual systems are 2.25". They are also not made for your car year, most of them anyways.
Old May 12, 2007 | 01:08 PM
bogus's Avatar
bogus
true duals cost power. all for the sake of sound. that seems very myopic to me.
Old May 12, 2007 | 01:14 PM
Aardwolf's Avatar
Aardwolf
Since the later C4 exhaust is dual, people would gain power by going to a single pipe? I haven't heard of that before.
To x or true dual
Old May 13, 2007 | 01:19 AM
mike43725's Avatar
mike43725
true duals = more hp not less.
Old May 13, 2007 | 01:27 AM
bogus's Avatar
bogus
It's like half the people here have never heard of a thing called the "x-pipe."
Old May 13, 2007 | 02:32 AM
MexCareBear
well ok i have another question.....do i loose any power doing a true dual or gain more power..and does it sound good....now with the x-pipe, do i loose or gain any power and does it also sound good(i know it gives you low end torque)...like i would like to know witch is better before i do it
