Quick help...window wont go up
Old Oct 21, 2001 | 07:49 PM
Shayne's Avatar
Shayne
Default Quick help...window wont go up
Im stuck at work so cant check it now...but drivers window works but passenger stopped half way and wont continue up.....I cant hear the motor turning...and I just replaced the belt 3 weeks ago...any ideas as to what I should check at lunch.
woops its an 86 coupe
[Modified by Shayne, 9:49 AM 10/22/2001]
Old Oct 21, 2001 | 10:06 PM
bogus's Avatar
bogus
Default Re: Quick help...window wont go up (Shayne)
you may wanna try and lift it manually, with the motor running.
I hate the ribbons, tho... I would consider upgrading to the mechanical regulators....
It sounds like the ribbon may have jumped track.
Old Oct 21, 2001 | 10:14 PM
AS84's Avatar
AS84
Default Re: Quick help...window wont go up (bogus)
Sounds exactly like a broken ribbon. The passenger side of my 84 broke 3 times in 9 months. Does the 86 have a ribbon? I thought GM ditched those in 86..I dunno. I know 84-85 had them. Anyway it would be worth your while to upgrade to the newer regulator ecklers has them at 200.00 :eek:
Old Oct 22, 2001 | 10:09 AM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Default Re: Quick help...window wont go up (AS84)
Ive been lucky...I replaced the ribbons 5 years ago and theyre stillworking fine.
I think I got mine from MAD or someone,they were built of thicker plastic then the originals.
One thing you must do is make sure the track is perfectly clean of rust or grime, and lube the whole thing with alot of white lithium grease from the can you brush on.
The spray on lubes dont last.
What I did when my ribbon snapped, I took the door panel off and I lifted the windowto the top by hand and used a small worm style clamp and tightened it down very tight on the slider/aligning pole under the window to keep it up for a few days before I got the stuff I needed.
They stopped using the ribbon in late 86...they began using the improved regulators on the convertiblesin mid year.Us guys with the coupes got the left over ribbons so GM didnt have to waste moneyon all the ones stockpiled in the wharehouse.
Get your improved regulators from the junk yards if you want to upgrade and save money.
Old Oct 22, 2001 | 12:10 PM
into01000101's Avatar
into01000101
Default Re: Quick help...window wont go up (Bill's86Coupe)
Man, oh man, I was faced with this same dilemma. In 1986 the coupes had the ribbon track, and the verts had the better unit used until 96. The ribbon on my driver side broke, so I went on Ebay, bought a NEW late model unit for $45, and it bolted right in (alignment was a pain) . I also put dynamat in the door's interior, and then the quiet door panels that MAD/Ecklers/Zip offers. The window is so fast now! Amazing. IT is a worthwhile investment, believe me.
To Quick help...window wont go up
