Really need some help, please
Old May 16, 2007 | 07:28 PM
Demonic85's Avatar
Demonic85
Default Really need some help, please
Having some problems again, heres whats been going on...
I put new heads on it a few weeks ago, had a mechanic adjust the rocker arms and timing. He says my fuel pump is going out. I replaced the pump and the car runs fine with a slight miss every now and then and it overheats.
Last Friday it started running really bad, made it around the corner and shut it off. It was leaking fuel out of the back of the fuel rail. I fixed that and it ran fine again. A little rough at first but smoothed out.
Last night I adjusted the timing to 6* BTDC it was at 10*. Went out for a drive, but it started storming real bad so I went home. This morning it'll start up, run for a second or two and die. When I give it gas it sounds real rough and will die when I let off. I checked vacuum lines, its all good. Getting spark too. I have no idea whats wrong and its driving me crazy. I really need some help.
Old May 16, 2007 | 07:43 PM
CFI-EFI's Avatar
CFI-EFI
Are there any codes set?
RACE ON!!!
Old May 16, 2007 | 07:47 PM
RedCorvette1988's Avatar
RedCorvette1988
Has the fuel pressure been checked? The fuel filter could be plugged.
Old May 16, 2007 | 07:55 PM
Demonic85's Avatar
Demonic85
There are no codes being set and the fuel pressure was checked by the mechanic which is how he narrowed it down to the pump. A guy I work with said it could be a bad alternator or battery. The battery is only a few months old.
Old May 16, 2007 | 11:09 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
A clogged fuel filter can also give sym of bad pump.
Check battery voltage, and alt to battery charging: Search for procedure and info.
Leaking injector, check plugs, check cap
Old May 16, 2007 | 11:19 PM
Demonic85's Avatar
Demonic85
New cap, new rotor, new wires, new plugs. Voltage is around 14.2-14.5 volts so its all good. Well I tried to keep it running a little bit ago, it ran rough until it warmed up and then ran fine.
I adjusted the belt tensioner cause it was wobbling up and down, so I tightened that up. I put the timing back at 10* BTDC to see if that would have an effect.
So I guess it runs rough until warming up, which makes me think of leaking injectors or something. Your thoughts?
Old May 17, 2007 | 08:43 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Do you have a gauge ?? A little diagnostic work will let you know if it is an injector leaking.
http://members.shaw.ca/corvette86/Fu...mDiagnosis.pdf
Old May 17, 2007 | 09:08 AM
Demonic85's Avatar
Demonic85
Man I really need a fuel pressure gauge. My other car gets code 44 and runs like crap. I'm gonna keep testing the vette and i'm sure its something stupid like it always is.
Old May 17, 2007 | 10:50 AM
CFI-EFI's Avatar
CFI-EFI
Ohm check your ECT sensor against the values in your FSM.
RACE ON!!!
To Really need some help, please
