Afr 195 Head Flow #'s
Mikey, don't know if you were asking Bill or me on the cam selection. Mine will be a .6" lift solid roller with 240'ish duration at .050. LSA will be around 110. Engine is a 4.125 bore x 3.5" stroke for 374 CI. Compression is 10.5:1. Engine Analyzer shows some pretty nice numbers for this combo, but this doesn't mean much until the engine hits the dyno......
FWIW, my older AFR CNCd 195s outflowed the advertised numbers as well, peaking at 292 cfm @ 600 lift. Looks like they're consistently performing, despite the naysayers
