Really bad timing (pic)
Your dizzy is in wrong,just pull it and do it right(look at Agent 86's pic),in another statement you said timing was about right???Why not right on?is it because you can't turn dizzy
? did you disconnect est before setting?First put the dizzy in right then go from there.Also take a long screwdriver and a light, turn oil pump drive shaft so the slot is in the 5 o'clock posistion this may help you drop the dizzy in
You're never going to get this car to run right until your timing issue is corrected. The idel could very well be attributed to either the IAC or a vacumn leak, but you'll never know until you follow the proper steps!
2nd, then you set rotor position (this is a good time to pull dizzy to reorientate having distr. body where you want it).Rotor should be orientated slightly before no.1 THEN go through firing order (RE-DO!). Make sure all wires are completely snapped on to the terminals.
Like others already said, that F.O. doesn't look right despite your saying it is, look at my pics. at where no.1 is. The location of the distributer shows me someone had it out and set it back w/out consideration to location to the firewall (one tooth back). It would still run, the difference is the lack of room to turn the dist. for timing correction.
From the car being able to start shows you have spark, fuel and air. If no-one has changed anything else, another thing that could contribute to timing issues woulld be if the dampner ring has slipped and is creating a ficticious timing mark.
3rd, Quit worrying about what a mechanic told you if that was entirely correct your car would running correctly wouldn't it? start working the problem step by step.
If you have a 2nd person available while your finger is over the hole have someone click the ignition over (dont sit there and crank it)..Youll know when its on compression stroke, a rush of air will try and blow your finger off the hole. Take your time and try it again.
Based on what I'm reading, it sounds like my distributor is in the wrong location too.
However, I'm able to successfully time to 6*BTDC.
The car seems to be running great.
I do have a puff of black smoke coming out however.
Other than having it in a slightly inconvenient location, is there any other issues I could have for my distributor being located slightly different?
With it running well and able to easily get the base timing, it sounds to me like everything still lines up fine.
Is there anything I may be missing since it seems like everything is in line?
I'm trying to figure out why I'm running rich right now, so every little bit of info is helpful.
As for not being beyond your mechanical skills, its not about mechanical skills. Its about diagnostic skills. And apparently, it is a little beyond yours. No offense.
Something to consider; How much money do you earn an hour? If you spend 10 hours on this thing, and not figure it out, would it not have been cheaper to take it to someone who could find it in an hour? Not to mention the parts you may end up buying/replacing needlessly. Not to mention possibly saving your sanity.
I know conquering something like this gives you the warm fuzzies, but it may also cost you more in the long run.
Find a really good diag guy, and take it to him. Make sure you dont have to pay if its not fixed. Thats my policy, and should be everyones.
I use one of those crazy flexible carburetor nut drivers to pop the cap screws off with ease. That said, I'm not gonna mess with mine!
along with pluging in the tach and power.
