Steering Wheel replacement
Old May 24, 2007 | 08:46 PM
86GoldProject's Avatar
86GoldProject
Default Steering Wheel replacement
I'm planning on swapping my beat up factory steering wheel with a grant gt wheel I had on my camaro, is there any special adaptor or anything I'll need?
Old May 24, 2007 | 08:54 PM
Terrible Juan's Avatar
Terrible Juan
Yes, you will need adapter #6400 from Grant.
I am curious to know whether or not it is possible to use this same adapter on an airbag-equipped C4. Does anyone know if the C4 steering wheels are interchangable?
Old May 24, 2007 | 08:56 PM
teufelhund's Avatar
teufelhund
Yes you will need an adapter. Just get the grant adapter from any shop that sells grant wheels. Pepboyz even has them. You will also need a steering wheel puller to make life easier although I assume since you put one in your camaro you already knew that.
I used Momo but they are the same basic principle.
Old May 24, 2007 | 08:58 PM
86GoldProject
So I will need a different adaptor than the one I used for the camaro? Is is specific for a corvette? Can you retain the telescopic function?
Old May 24, 2007 | 09:00 PM
86GoldProject
Thanks for the part number! That's exactly what I was looking for
Old May 25, 2007 | 02:28 AM
ModifiedLT1's Avatar
ModifiedLT1
If you use a Momo wheel do you still use the grant adaptor?
Old May 25, 2007 | 02:40 AM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Not sure...ONLY if the wheel can bolt onto it.If the steering wheel has the same holes to bolt to the adaptor,and it requires an adaptor,then sure you can use it.Just find out from the suppliers if it uses the same bolt patterns or same adaptors.
Old May 25, 2007 | 11:31 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
The grant adapter allows tele functions. I don't know about mixing momo and the grant adapter....I went with grant all the way, and all fix and worked fine:
Old May 25, 2007 | 11:43 AM
comp's Avatar
comp
looks good
Old May 25, 2007 | 12:35 PM
Chatman's Avatar
Chatman
There are adapters available to go from Momo to Grant hub or Nardi to Grant hub. There is a Momo to Grant currently listed on Ebay at $32.
Old May 25, 2007 | 12:48 PM
MorpheusGPR's Avatar
MorpheusGPR
I am going to be doing this very shortly as well. The stock steering wheel is all chewed up and nasty.
Good info here on that adapter, and the above car looks super.
Old May 25, 2007 | 02:11 PM
Aggravated4life
Looking good!!
Btw,years back when I got my adaptor for my former 86,I took it to a body shop.The wrinkle satin like finish was not to my liking,and you can see it in the above photo somewhat how its an off color.
I dropped my adaptor off at the body shop and 10 bucks later,received it painted gloss black.Looked much better on the steering coulmn when sprayed gloss black.I could have used spray cans,But knew a painted finish from the shop,would be way superior to a spray bomb.
Old May 25, 2007 | 03:17 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
MOMO makes an adapter for the telescopic wheel. Try these guys:
http://www.ltbmotorsports.com/steeringwheel.html
You can replace an airbag wheel with a new MOMO, Sparco, or Grant.
You just won't have an airbag any more.
I have complete instructions on replacing an airbag wheel with a MOMO adapter and steering wheel, including the steps that must be taken to fool the electronics into thinking the airbag is still there. (Otherwise, you'll have the "AIRBAG" light on all the time.)
PM me if you want them.
Larry
code5coupe
__________
Not easily impressed....
Old May 25, 2007 | 04:30 PM
Terrible Juan
Larry
code5coupe
__________
Would you mind posting up that information? I would love to do that on my car. This would work for an LT1 car, right?
Old May 26, 2007 | 09:23 AM
Kool88vette's Avatar
Kool88vette
Here's a Momo wheel with a Momo adapter on my 88 vert. It has a Grant horn button. It's a simple install. Took about an hour. Make sure you have all the right tools. You need a wheel puller, a spring compressor and special pliers for pulling the clip. The adapter on Vinnies Vette looks like mine so I think Grant and Momo use the same manufacturer. You can keep the telescopic and cruise control.
Old May 26, 2007 | 02:11 PM
86GoldProject
wow that's a lot o wood!
Old May 26, 2007 | 09:25 PM
RED BARON's Avatar
RED BARON
Just a heads up in Virginia, some inspection places WILL NOT pass a car with a different steering wheel unless it is exactly the same size. Not all places are this strict but some are and it is posted on the things to be checked. We found out about this when my sons car was rejected for this reason.
Old May 26, 2007 | 11:07 PM
Aggravated4life
Serious? WOW...years ago I lived in a state with safety/emissions every year and never heard of such a thing..In fact when I got my auto classes done and Inspection license,some auto certifications,I used to inspect cars(In NY state) and do not recall ever hearing about the steering wheel,unless maybe an airbag wheel was removed?
I cant recall,its been a long time,but never heard of it..that being said,it DOES NOT SUPRISE ME ANYMORE at the lengths the rules go to fail a car for the stupidest chit imaginable.
Old May 29, 2007 | 01:12 AM
Chance's Avatar
Chance
From: I was a young troubadour when I rode in on a song, and I'll be an old troubadour when I'm gone.
St. Jude Donor '08
That Grant adapter pictured above looks a lot like what I have.
I have tele functions too.
I bet that's what I have!
To Steering Wheel replacement
