light bulb relacement
Old May 25, 2007 | 08:21 PM
bjcenter's Avatar
bjcenter
Default light bulb relacement
any one know the easiest method to replace the tail light bulbs (stop/turn) on a 1990 coupe...i have one burned out and i figure as long as i am in there i might as well replace all four...thanks bri
Old May 25, 2007 | 09:20 PM
subman's Avatar
subman
Remove licence plate and get out your long arms. Actually, I found the easiest way is; Remove lic. plate, reach the closest socket. You will feel a "squeezable" lever on one side. Squeeze and turn c/cwise. That's the easy one. If you have long arms, the outboard sockets are the same. But you have to remove and replace the bulb one handed. A bit of a PITA. I removed the lens, removed the 2-10MM bolts that hold the housing to the body (left and right of the housing, slightly below horizontal center), removed the housing (all easy through the licence plate cavity) and the outboard light sockets are then easily accessible. Then you can use 2 hands to r&r the bulb. Use a little bulb grease when re-installing the bulbs. And, as the book says, replacement proceedure is reverse.
Good luck
Subman
Old May 25, 2007 | 11:42 PM
Greg Gore's Avatar
Greg Gore
Good plan to do all four. Job teaches you to want all new bulbs in there rather than just one new one.
Old Jul 28, 2007 | 01:23 PM
DreDaDevil's Avatar
DreDaDevil
7th Gear
Default is there another way?
Good luck
Subman
i hope that there is another way. I have short arms.
To light bulb relacement
