87 timing
Old May 29, 2007 | 09:51 AM
87 crazy's Avatar
87 crazy
Default 87 timing
I know this is an easy one! I went to check my timing so I looked in the Chilton. I know to disconnect Ecm but my wiring harness is in the way???? How do you get to the cream and black disconnect wire????
Old May 29, 2007 | 09:53 AM
scorp508's Avatar
scorp508
It should be over near the rear of the distributor and wiper motor with a weatherpack connector you can disconnect there.
Old May 29, 2007 | 10:32 AM
vader86's Avatar
vader86
You disconnect the EST wire to the distributor, not the whole ECM.
Old May 29, 2007 | 10:46 AM
87 crazy's Avatar
87 crazy
Ok is the EST wire in the harness???????
Old May 29, 2007 | 10:55 AM
Wheelman's Avatar
Wheelman
Mine is by itself, on the drivers side of the engine bay underneath the brake booster.
Old May 29, 2007 | 03:23 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Single tan/black stripe wire. After you disconnect it and set your timing, you will need to disconnect the battery for a few seconds to clear the code 43.
Old May 29, 2007 | 05:01 PM
RRT vette's Avatar
RRT vette
Old May 30, 2007 | 10:20 AM
87 crazy's Avatar
87 crazy
Originally Posted by RRT vette
Thank you for the picture I can alway's count on you guy's
To 87 timing
