Corsa
Old May 30, 2007 | 01:07 PM
JohnyH's Avatar
JohnyH
Default Corsa
I picked up my Corsa cat back system yesterday, I was looking over the clamps that come with it and wondering if it would be advisable to use some sort of muffler cement when clamping them on? Or does someone have any other useful advise?
Thanks, John
Old May 30, 2007 | 01:28 PM
polo91cnvt's Avatar
polo91cnvt
I installed the Corsa cat back on my 91 last fall, and it works great. Used the clamps provided and followed the instructions and torqued the clamps before running and after. I have heard that if there is a problem the best way is to have the unit spotwelded. But I would go with the just the clamps until a problem exists.
Good Luck, Polo
Old May 30, 2007 | 02:11 PM
msslp04's Avatar
msslp04
St. Jude Donor '11,'14
Good Luck, Polo
Put mine on last week and no problems. Easy to install too.
Kevin
Old May 30, 2007 | 02:22 PM
jwt1603's Avatar
jwt1603
Good Luck, Polo
I've had the Corsa on for two years now. All I ever did was tighten it up a little after it went through a couple of heat cycles. I've taken it off several times for various reasons and have never had a leak problem. If you use the cement it will be harder to take off and put back on without creating some leaks.
Old May 30, 2007 | 02:55 PM
dchildress's Avatar
dchildress
Old May 30, 2007 | 04:37 PM
wayne lowry's Avatar
wayne lowry
Thanks, John
no muffler cement, if it leaks you can buy wider flatband clamps but it should not leak. They sell a quality product and for the money it should be.
Old May 30, 2007 | 04:46 PM
Strick's Avatar
Strick
B&B has the same clamps and they just didn't do the job for me. I had a guy that is great with S/S welding spot weld it while it was on the Vette, aligned perfectly, and then I removed the whole system and finished the welding of all the unions, just like the OEM cat back. Makes taking it off easier and it looks better than the clamps.
Old May 30, 2007 | 06:35 PM
JohnyH's Avatar
JohnyH
Thanks for all the replies, is there a gasket between the back of the Catalytic convertor and the first pipe going back?
John
Old May 31, 2007 | 11:00 AM
GKK's Avatar
GKK
There's no gasket on the outlet of the catalytic converter, the connection is a ball and flange type.
Also, I noticed slight exhaust leaks where the clamps are when I installed the Corsa's on my "91" L98. I sprayed windex around each clamp and saw the leaks.
I also, wanted a cleaner look so, I had a muffler shop remove the clamps and weld each joint. looks a lot cleaner now.
Old May 31, 2007 | 12:13 PM
JohnyH's Avatar
JohnyH
Thanks for the reply, I'm hoping for no leaks but if it needs welding it will get welding!
Old May 31, 2007 | 02:54 PM
Strick's Avatar
Strick
Just make sure they use S/S rod or you'll have a rust prone joint.
Old May 31, 2007 | 07:57 PM
VenkmanP's Avatar
VenkmanP
I've had the Corsa on mine for 3.5 years, and it always loosens up and gets louder after a while. Have redone the clamps several times, and had the entire system off once.
The next time I take it off I will use some kind of sealer on all the joints. Was thinking to use high-temp RTV.
Old May 31, 2007 | 08:58 PM
JohnyH's Avatar
JohnyH
It took a couple of hours, mind you I have air tools and the car sits on a four post hoist. Does it sound sweet and looks even better! I was quite surprised that the old exhaust, 19 years on, came off as easy as it did! No leaks and I'll retorque the clamps after it has cooled off. Now it's time for a high flow cat!!!!!!!!!
To Corsa
