Is this the "VATS" problem
Old Jun 1, 2007 | 02:55 PM
seenalot's Avatar
seenalot
Default Is this the "VATS" problem
Car has been running great last two months, EVERYTHING works on my stock 1989 Coup with automatic transmission.
Today drove it about 15-20 miles at lunch, ran into a post office and when got back into the car, turned the key and dash was normal but NO STARTER sound. Shifted out of park, into neutral and still no starter.
About 1.5 - 2 hours later car started right up. If this is the VATS system starting to act up I'd like to know how those VATS bypass system works.
Old Jun 1, 2007 | 03:11 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
could be, maybe the key was wet or dirty. It could also be a bad starter solinoid, nuetral safety switch, ignition switch or battery/cables. If it happens again check to see if the security lamp is out. No security lamp = no VATS problem.
Old Jun 1, 2007 | 03:20 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Could be, check to see if you have a code 46 stored in the ECM.
http://members.shaw.ca/corvette86/Code%2046.pdf
Old Jun 1, 2007 | 11:46 PM
staugur's Avatar
staugur
posting on two forums eh!!!Do a forum search,all will be revealed.In my case it was the starter enable relay.
To Is this the "VATS" problem
