Was just uploading and the fans came on (as they should), but never turned-off, and the program never completed uploading. This is the second time this has happened to me.
I'm using TunerCat ($EE program for '95 LT1) in Win98 on a laptop that is ONLY used for programming/datalogging (no internet, so should be Virus-Free).
Is there something I can do BEFORE trying to upload so I know there is proper communication? Damn, this is getting expensive!!!
TJWong, are you still rebuilding? If so, please PM me w/ your address.
Yeah, the ignition is in the "On" position, and I always use house power when uploading (just don't trust batteries)...
Is there ANY possibility of "Crashing" when READING the PCM? If not, should I try READING the PCM first, just to see if it's communicating, then PROGRAM it?
Never disassembled the cable, so can't say for sure (It's the cable everyone seems to use...from "Andrew", I believe). I never had a problem READING, just when Programming... if that matters???
I guess I'll do what I can to make sure there's good communication first.
THanks!
YES! I always read 2 or 3 times before trying to program. I also ensure the screen saver and power savers are disabled on my laptop. Also, ensure you have the latest version of TunerCAT. I think they made some improvements in the PCM flash code.
I was in your shoes before. TunerCAT took a dump a little more than 1/2 way through. I ended up removing the flash chips from the PCM and soldering sockets on the board. Then I programmed two new flash chips on my desktop EPROM programmer and plugged them in. After that I struggled with FEDS for a little but eventually it figured itself out and was fine.
Also, never never use a USB to Serial adapter. What kind of cable do you use?
Don't really know the technical components of the cable (not using the USB port though)... it's the cable from "Andrew" @ AKM. I believe most of us on the forum use it.
Yeah, think I'll be doing a few READS first, THEN I'll do programming.
Thanks!
Double check your winflash program to make sure its the latest version. Do that as well with your TC program. I normally use a off board cable to program PCMs with so that assures that there are no other devices that are attempting to communicate with the PCM.
I can say that I have had one PCM crash on me during a reflash in the car, it even told me that the programming was complete but the PCM had died for some reason in the process. I even went through the process of desoldering and soldering in sockets, but there was something else wrong as the PCM was dead to the world. In this case the only option was to go with a reman PCM from AC Delco.
I just killed my ECM tonight. I have a 95 pcm in my 96 so that I can tune it myself and I have already killed it. The fans stay on and I have a really fast blinking SES light. I just got the ECM from PCM for less too . This really sucks. I am using TunerCat Win flash, TunerPro RT to modify the bin. and datalog. For hardware I have a Moates Autoprom and a Moates cable. The Autoprom uses a USB to serial software to create a com port. It seems like someone would know exactly what to do to keep this from happening.
I took the ECM apart and saw the FLASH chips, where are you guys getting those? What kind of programmer are you using to flash them outside the ecm?
Seems the OBD1 and 2 computers for the LTx motors are kinda finicky. I have had issues on and off, with both versions. With no consistancy what so ever. I have had PCMs take a dump both reading and writing (flashing)
The good part is when they have a failure during a read, they almost always recover. Disconnect the battery for a 1/2 hour or so, and they come back.
Had one take a dump at the racetrack, and when we got it home an hour later, it started right up and we backed it out of the trailer.
Had a Grand Sport take a dump in the middle of a read, in Hockenheim Germany, and the guy was from France. I just new I was gonna get this guy stuck several hours from his home. Luckily it came back to life also.
Been there, done that. You're gonna need to get those flash chips off the boards and solder sockets in their place. I used my EPROM Programmer (Pocket Programmer 2) to program my flash chips before plugging them into the sockets. The tricky thing is you can't just dump the BIN file into the chips. You need to split it into two files, and translate them because the address lines to the chips inside the PCM are crossed. I created a small program to do this for me, once someone told me how the address lines are wired in the PCM. Anyway, it worked for me and brought my '95 back to life. You can have the program if you need it.
Ion Soltan helped me out with new chips and sockets. ion@soltan.net
Here is a link to download. It is just a simple VB6 program, source is included. Just run the EXE, give it your BIN file, and it will create two Flash images for you. The filenames will indicate which side of the board.
If you are buying new Flash chips from Ion and don't have an EPROM programmer, he may program them for you if you send him the two image files you'll get from this program.
I believe the most common cause of PCM 'crashes' is vehicle battery voltage. I always verify that it is 12.6 or above (igntition off) before I start and no lower than 12.3 with ignition on. Be sure to turn off all accessories and set e-brake to kill the DRLs (if so equipped). I have also always shorelined the laptop when flashing because I don't trust batteries.
Thanks, I went to the junk yard and got some PCM connenctors out of a Caprice, along with the diag port. I bought a project box and a 13.5 vdc power supply from radio shack and built a setup to flash the PCM outside of the car. I installed SES, Fan 1, Fan 2, and fuel pump indicator lights to see whats going on. I will post a picture of it if I get a chance.
Make sure you have the latest EE/EEB XDF files for TunerPro. I've seen some floating around that have invalid checksum calculations.
The corrected ones are on Moates's file manager.
I downloaded the latest version of the .xdf files from Moates. It looks like the EE.xdf is the same as the one I already have. What car is the EEB.xdf for?
How do you know it's the same? There are exactly 2 characters that are different between them, other than the date and time stamp.
The checksum end addresses were edited. (Compare the checksums from the XDF you had before to the XDF you recently re-downloaded).
