help rough idle, bad acceleration still
Old Jun 5, 2007 | 07:10 PM
thumper823's Avatar
thumper823
Default help rough idle, bad acceleration still
85 tpi, wont idle below 1,000 rpm +bad acceleration.
new plugs, cap, rotor and wires.
idle/IAC adjusted to stock
ignition timing adjusted to stock with est disconnected 6 deg.
cat not plugged
injectors cleaned, should i have just bought new ones?
no check engine light???
cant find any vacuum leaks, are there any good methods to check this?
replaced fuel filter, checked regulator and checked fuel pressure (around 28psi)
acts like the ignition timing is off, but i corrected it and the balance is not spun.
this engine is stock with 52mm TB
whats next. ecm?? like most of you i dont want to spend $800 on parts i dont need to fix the problem.
help would be awesome
updated..... new IAC and EGR valve..... same problem
Old Jun 5, 2007 | 07:34 PM
Demonic85's Avatar
Demonic85
Mine is doing the same thing, so i'll wait and see if you can fix yours
Old Jun 6, 2007 | 07:35 AM
85C-4's Avatar
85C-4
I experienced a similar situation, make sure the fuel pressure regulator diaphragm is not leaking. Also, verify fuel pressure and make sure the filter is good-
Good luck
Old Jun 6, 2007 | 08:36 AM
thumper823's Avatar
thumper823
Good luck
oops. forgot to put those in my original post. i have already replaced fuel filter, checked regulator and checked fuel pressure (around 28psi)
Old Jun 6, 2007 | 09:01 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Whats your fuel pressure under load ?? (driving with gauge taped to windshield)
Old Jun 6, 2007 | 09:43 AM
thumper823's Avatar
thumper823
i can't really put this thing into gear without it stalling out. last time i drove it, i had to neutral drop into gear
Old Jun 6, 2007 | 10:12 AM
AGENT 86's Avatar
AGENT 86
OK, then what pressure to you get with vac line removed from reg ??
Old Jun 6, 2007 | 11:57 AM
Square's Avatar
Square
To find vacuum leaks:
1)Find someone who smokes (if you smoke then your set)
2)Buy a section of clear tubing (5 ft minimum)from Lowes/Home Depot ($3)
3)Remove the snorkle from the air filter to the throttle body
4)Slip one end of the tubing under the throttle plates
5)Tape up the throttle body and tubing with duct tape so it is sealed
6)Have the smoker exhale smoke in the tube. it will take a few minutes for the intake to fill with smoke. If there is a vacuum leak, smoke will appear
7)Use a flashlight to pinpoint the source of the leak.
P.S. for lower runner/base manifold leaks (L98 engine), it may be necessary to remove the valve covers and wiring harnesses to see exactly where the leak is coming from. If you do this, make sure you unplug and tape up the PVC system. otherwise the smoke billow out of the open valve cover and cause confusion.
I have used this system successfully several times.
I got this idea from the forum here.
HTH!
Old Jun 6, 2007 | 12:31 PM
85C-4's Avatar
85C-4
One other thing I forgot to note- it sounds a lot like a bad or stuck EGR valve too-
Old Jun 6, 2007 | 01:08 PM
Abel's Avatar
Abel
5th Gear
I experienced similar issue with one of my previous 85s due to water in the tank, my drain hose from rubber cup around fuel filler was stopped up and water was sucked into tank when it rained.
Old Jun 6, 2007 | 01:23 PM
jghmczo6's Avatar
jghmczo6
Almost identical problem occured with my '90 vert, o2 sensor was bad and I had to replace all 8 injectors. Check the o2 sensor first then the injectors.
Hope this helps
Old Jun 7, 2007 | 08:27 AM
thumper823's Avatar
thumper823
at idle, because this car will only idle for a second
Old Jun 7, 2007 | 08:32 AM
thumper823's Avatar
thumper823
HTH!
why didn't i think of that i tried it and i think its leaking from either the iac, or the bottom cover on the TB. i will look at closer tonight. thanks
Old Jun 7, 2007 | 08:33 AM
thumper823's Avatar
thumper823
my car was outside in the rain a couple days. how did you find out there was water in your tank? did you drain a fuel line and find water?
Old Jun 7, 2007 | 08:36 AM
thumper823's Avatar
thumper823
Hope this helps
i have replace the o2 sensor when i bought the car. i would like to buy injectors seems a couple had some gunk in them. which does'nt suprise me at 116k
Old Jun 7, 2007 | 08:49 AM
AGENT 86's Avatar
AGENT 86
Ok, what's the pressure when you apply 12 volts to terminal "G" of the ALDL, with the motor not running.
Old Jun 7, 2007 | 09:19 AM
conv90's Avatar
conv90
HTH!
...and what about the smoke going in the open valves?
if the engine is in a situaation where (at least 1 of 8 combustion chanbers are in this situation..) there is overlap (intake and exhaust valve open), the smoke can go in the exhaust...
,...And the smoke that goes in to open intake valves? are we sure about the ring seal?
I don't think it's a good way to test leaks...unless it is made under pressure. A leak can't be detected (even if it's present a noticeable hole) if there is not a difference of pressure.
-Beppe-
To help rough idle, bad acceleration still
Old Jun 7, 2007 | 02:04 PM
Square's Avatar
Square
-Beppe-
Well, what I can tell you is that the force of a person exhaling is enough to push smoke out of a leak point in the intake. I usually have to ask my smoker to exhale slowly in order to pin point the leak.
As for smoke making it way into the exhaust, I am sure that does occur, but it still comes out of the vacuum leak as well.
There may be a better way, but I have used this method successfully on several occasions.
Old Jul 2, 2007 | 11:18 AM
thumper823's Avatar
thumper823
i will check that tonight, when i'm done with work. which terminal is "G"?
Old Jul 2, 2007 | 10:43 PM
thumper823's Avatar
thumper823
38 psi with 12v to terminal G. does that sound right?
