optispark installation problem...
Old Jun 10, 2007 | 06:59 PM
ninetyfivevette's Avatar
ninetyfivevette
Default optispark installation problem...
I'm installing a new optispark my fresh engine and it will not seat flush on the timing cover. I cannot find my old cam sprocket bolts, but I suspect the ones are standard SBC bolts. The bolt heads are about 0.200" but the reliefs on the opti are 0.160". Are cam sprocket bolts for the LT1 specific? I have a feeling they are since I am about 0.040" away from it mounting flush...
I'll see what Summit has to say in their catalog.
Old Jun 10, 2007 | 07:16 PM
MikeC4's Avatar
MikeC4
any possablility it is just the dowel pin mis-aligned?
Old Jun 10, 2007 | 07:19 PM
ninetyfivevette
I wish- the dowel is in the right spot. I also measured the length of the dowel and the depth of the mating hole in the opti and there is plenty of clearance.
Old Jun 10, 2007 | 07:25 PM
MikeC4's Avatar
MikeC4
Yeah, I kinda figured you had the dowel aligned properly, as you have done some homework on the cam bolt and opti measurements..... Bummer..
Good luck....someone else should chime in here...
To optispark installation problem...
