Question about deck height, LT4
Old Jun 11, 2007 | 01:49 PM
96lt4c4's Avatar
96lt4c4
Default Question about deck height, LT4
I just talked to my machinist about decking my block. He told me he likes to have at least .050 clearance including the head gasket. He said that parts can stretch and things can get close. I know some of you guys and a lot of other people are running zero.
I was wanting to deck it to .005 and run a .039 thick head gasket, .044 total.
Also my factory LT4 heads have been resurfaced. They removed .005 just to make sure they were good and flat..
I am trying to stay as close as I can to 10.8:1, .005 deck height will give me that. What do you guys think?
Old Jun 11, 2007 | 03:08 PM
VenkmanP's Avatar
VenkmanP
I think it's unfortunate that you chose a machinist who doesn't understand quench. Or else I think it's unfortunate that you chose a rotating assembly that's going to stretch that much...
Old Jun 11, 2007 | 03:16 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
That is what I have and no problems. I'm not using any forged parts, though.
Old Jun 11, 2007 | 03:26 PM
LD85's Avatar
LD85
I thought the stock "in the hole" was .025" (?) I could be wrong,
Old Jun 11, 2007 | 05:10 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I'm running .041" quench and would have run it at .034-.035" except I didn't want to wait on special gaskets. .040" is generally considered to be quite safe.
Old Jun 11, 2007 | 06:50 PM
CFI-EFI's Avatar
CFI-EFI
You are right, but...
What does STOCK have to do with anything???
Chevy puts their OK on .035", but what is hot rodding if it isn't pushing the limits. My new engine has a zero deck and I'm still P'ed at myself that the piston isn't sticking OUT of the hole.
RACE ON!!!
Old Jun 11, 2007 | 07:03 PM
Corvette Kid
Reading is fundamental.......
Old Jun 11, 2007 | 08:06 PM
96lt4c4's Avatar
96lt4c4
I think its unfortunate that you even posted in this thread with that kind of attitude.....
Old Jun 11, 2007 | 08:09 PM
96lt4c4's Avatar
96lt4c4
I will be running a fully forged Eagle rotating assembly with forged Mahle pistons. I guess it probably wouldnt stretch that much, so I will have it decked to .005.
Old Jun 11, 2007 | 08:10 PM
96lt4c4's Avatar
96lt4c4
I measured mine to be .026 on both sides, everything stock.
Old Jun 11, 2007 | 08:17 PM
LD85's Avatar
LD85
With .025" in the hole, where is he going to get anything other than a copper gasket or a shim to end up with .050" ?
I have never found anything other than Flatout gaskets for like $150 or more a set, or SCE Copper gaskets, both of which I have personally used. Stretch is related to the piston speed and your max RPM's, so you decide.
Solution, deck it to .005" and get the stock .039" gasket and don't quibble over .002 or .003"
CFI-EFI's Avatar
CFI-EFI
I would take it down a lot further. A piston to head clearance of .044" isn't a tight quench. Either that or go the .005" deck height you planned and use one of the Impala head gaskets. Perfect!
RACE ON!!!
Old Jun 11, 2007 | 08:25 PM
96lt4c4's Avatar
96lt4c4
RACE ON!!!
Do you have a part number for the Impala gasket? Right now I have the Fel Pro 1074 that is .039.
What about this one?
http://store.summitracing.com/partde...6&autoview=sku
Never mind that is for an Iron head..
Old Jun 11, 2007 | 09:04 PM
VenkmanP's Avatar
VenkmanP
I think it's unfortunate that you started this thread asking for people's opinions if you didn't want to hear them.
Good luck with the build, you're going to need it with that kind of attitude and that machinist...
Old Jun 11, 2007 | 09:19 PM
96lt4c4's Avatar
96lt4c4
Its guys like you who make me not want to post here. Some of us are here to learn, and do not already know everything.
Old Jun 11, 2007 | 09:48 PM
CFI-EFI's Avatar
CFI-EFI
I don't. It has been posted here many times. I'm sure a search will turn up a part number for you. It is .028" thick, compressed. .028" + .005" = .033". Now THAT'S a nice quench!
RACE ON!!!
Old Jun 11, 2007 | 10:49 PM
JimMel's Avatar
JimMel
RACE ON!!!
To Question about deck height, LT4
Old Jun 11, 2007 | 11:39 PM
STL94LT1's Avatar
STL94LT1
GM part # 12553160
Old Jun 12, 2007 | 07:22 AM
96lt4c4's Avatar
96lt4c4
Originally Posted by STL94LT1
GM part # 12553160
Thanks you sir
Old Jun 12, 2007 | 07:28 AM
96lt4c4's Avatar
96lt4c4
I just did a search for that gasket, and Pace shows that it is for iron head engines. I guess you guys are running them on aluminum head engines with no problems? I am sure it has been talked about here before, I will do a search.
http://paceperformance.com/index.asp...&ProdID=180531
