I installed a set of TPIS headers and Y pipe. I re-install the stock O2 Sensor. My Question is do I need to switch to a heated O2 sensor? What is the difference between a heated sensor and stock sensor, and do I need to make the switch?
It is not required. I see no reason to install one unless your stock one is original or going out, and youre going to be replacing anyway, unless you are having open/closed loop issues. I do not run one with my headers, and dont plan to.
Difference is that the heated one is hooked to a 12V source and sends good signals to the ECM at lower exhaust temperatures, so the car doesnt drop out of closed loop at idle or part throttle with the heated O2.
Thanks Vader86 ... I had my vette for a few years, and I still have a few things to learn about it. I'm no stranger to carburated engines, but TPI I'm still learning. Just one more question. Could you explain open and closed loop? Does it have to do with the engine reaching the temp to adjust the idle?
I have two different sets of headers.One has the 02 at the bend before the horzitonal pipes and causes no problems.
The set with the sensor in the collector drops out from cooling at idle requiring a heated sensor to read correct.
Just for reference, I am 100 miles north of you, and I have the TPIS headers. The car goes to closed loop and works fine even in the winter with the stock O2 sensor.
I've run TPiS headers for 8 years and you DO NOT need a heated O2 sensor. I live in the land of fat women and cheese too so it gets a little colder here.
On the other had maybe you do need a heated O2 if some CFC4T expert that has never run these headers tells you that you do.
Yes some brands have the sensor further away, or may not be coated at all, thus some feel the heated one is needed.
For the OPs headers, it is not that way.
With TPiS headers, it sounds as though the OP does not need a heated
O2 sensor.
For others with a sensor in the collector, such as the Stainless Works
pipes, a heated sensor can make the difference between achieving/retaining
closed loop quickly - vs - not achieving CL or dropping in & out because the
unheated sensor is not hot enough to generate a signal.
