Anyone else measured the total amps drawn from the battery with everything OFF- ignition, lights, etc?
I'm seeing .5 amp which seems high; no wonder the battery is always dead if you don't drive it. Should anything else be on besides the anti-theft? I'm going to pull a few fuses and see if I can pin it down better.
If you've got any aftermarket stuff (cell phone, stereo) hooked up check that out, too. There was a cell phone installed in mine when I bought it and after 5 days of sitting it wouldn't start. I uninstalled it as soon as I discovered that was the problem.
PS: I also don't go 5 days without driving it anymore either!
all of the above. the ECM does drain constantly on all cars but shouldn't be a high amount.
Heard a group of mechanics debate that one until they did a test in the shop.
someone lost an expensive dinner. :lol:
Thanks for the ideas so far guys; to answer a couple questions:
No lights on at all; even pulled the "Courtesy" fuse.
I'm measuring with a digital meter directly in series with the battery.
As far as I can tell, the only things that should draw current are the Theft system, radio clock, and ECM.
I've also noticed some noises when re-connecting the battery that sound like the headlight control unit is doing something (also initial current draw of >5amps).
FYI... my battery would die after a week of sitting...Security light would not quit flashing after motor is off even with doors closed. Turned out to be the Theft Detterant Module. No more dead batteries:)
If all other checks fail (don't forget to pull the breakers near the fuses), you might end up tracing it down to the starter or the alternator. Remember, these aren't directly fused, so pulling fuses ignores them. -Matt-
Re: Battery current draw when sitting? (HighHopes85)
First, make sure the key is out. If it is in, the CCM will go into "wake-up" mode. The current draw on my 90 (from memory, don't have manual anymore) was 15-19 milliamps (0.015-0.019 amps) in the manual. If you have a Lojack, it will be about 8 to 10 milliamps higher. 1/2 amp is WAY too much. You have a short somewhere. I had a short once after bleeding the brakes because we bled the brakes too fast, but a few pumps of the pedal solved the problem. Go through your breakers pulling them one at a time to find out what circuit is the culprit.
