AC / Heat Control Panel
Old Jun 22, 2007 | 11:19 AM
csc67's Avatar
csc67
Default AC / Heat Control Panel
I pulled out the AC/Heat Control panel due to the COOL button wasn't working in my 1989 vette. Couple people suggested I clean the contacts, but the unit looks sealed to me - HELP
All of the other buttons work (up temp, fan, rear defrost)
Here's what it looks like:
Old Jun 22, 2007 | 03:55 PM
jghmczo6's Avatar
jghmczo6
Clean the contacts where the control unit plugs into the electrical receptical. I have a '90 and mine is completely different, however I did have issues with not cooling properly. I Cleaned the contacts, checked the fuses, check the outside temp sensor (replaced dealer damaged it) disconnected the negative battery terminal waited ten minutes reconnected and everything worked, and that was a few months ago.
Hope this helps
