mass airflow sensor
Old Jun 22, 2007 | 06:35 PM
BTTB's Avatar
BTTB
Default mass airflow sensor
anyone know the proper way to test a mass airflow sensor on an 86
Old Jun 22, 2007 | 07:17 PM
All2kool's Avatar
All2kool
Borrow one that works (from ANY TPI motor).
Old Jun 22, 2007 | 09:08 PM
Aardwolf's Avatar
Aardwolf
Faulty MAF sensors will normally light the check engine light on the
drivers information center if the problem is constant and store a
trouble code. If intermittent, a trouble code will still be stored as
long as the battery is not disconnected.
Normally, the problem is a poor connection at the sensor and wiggling
the wires, unplugging and reinserting the connector will often cure the
problem.
A faulty MAF will normally cause a no start or difficult start condition
and although you can eventually get the car into the "limp-home" mode in most cases.
You can try tapping on the sensor to see if the idle changes, or unplug it and see if the car runs better. There is a MAF cleaner spray also. I had a MAF with a break in the wire, it was very hard to see. You can very gently push on the wire to see if there is break.
Old Jun 22, 2007 | 09:37 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://members.shaw.ca/corvette86/Code%2033.pdf
http://members.shaw.ca/corvette86/Code%2034.pdf
http://members.shaw.ca/corvette86/Code%2036.pdf
Old Jun 22, 2007 | 10:04 PM
shop14's Avatar
shop14
check engine light should be on,then go and check for codes
To mass airflow sensor
