Erratic timing and idle only with EST connected.
dont remember the brand. it was one of the above mentioened brands, just cant remember which one.
i do remember it came from China...
i remember him ranting about it...
"cheap chinese junk. i could crap in a mold, bake it in an oven, and machine a stronger part out of it than this one."...
not saying yours isnt decent quality, just that those imported pieces can sometimes fall short of OEM standards
Interesting reading here on Chinese labor, probably some propoganda, but still...
http://www.willthomas.net/Convergence/Weekly/China.htm
Scat cranks + rods, eagle cranks + rods, lot's of pistons, lifters, rockers, etc.
Your balancer will be fine.
I'd be weary of listening to the forum member who bought *a part* vs guys who have built numerous race winning motors.
CAT makes decent dampers too, btw.
-- Joe
Would you buy a crankshaft made by a 15 yr old girl?
RACE ON!!!
here you can see that all the holes in the perimeter are empty except for the one.
is referencing the one, ODD damper that takes weights.
Seriously, I have never seen or heard of removable damper balance
weights. Of course, I had never heard of removable flywheel weights,
either, until I read about them, here, on the forum as applicable to the DM flywheel used with the ML9 six speed trans. I even went to my
own FSM page 6A1-13, in my book, and found no mention of damper
weights as your book shows.
I have never come across anything like that before. I had written a different response assigning the difference to the 1986 and up dampers. Then as a double check, I looked up the dampers in my Corvette parts books. Contrary to my previous statement, all Gen I engines in all year C4s take the same damper. I appreciate the scan of the FSM. If I hadn't seen it, I wouldn't have believed it. This is a mystery to me. If the dampers were different I would write it off as just one more fact unknown to me, but the two different treatments in the FSM over the, supposedly same, damper has me totally confused.
By the way, the one piece rear main seal L98s ARE internally balanced in the front of the engine. I would like to put a call out to anyone that can shed some light on what is going on here. HELP!
RACE ON!!!
Your is an '85, isn't it? I didn't notice any in my '84, but like you, I wasn't looking. Either way, Why would the FSM not mention a weight in the '84 book, but say what mseven scanned from his 1990 FSM, when the dampers are the same???
RACE ON!!!
If the pin weight was to balance the damper, then the book shouldn't ask you to switch it to the new one.
Notice his new damper has an extra hole, perhaps to balance it.
You got the parts manual if you're so inclined to check. I'd rather scratch myself.
