How hard to replace LT1 Coil?
Old Jun 26, 2007 | 09:00 AM
Darkgh0st's Avatar
Darkgh0st
Default How hard to replace LT1 Coil?
Anything special I should know or is it pretty straight forward? Looks easy, 2 bolts. I suck at car stuff though.
Old Jun 26, 2007 | 09:01 AM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
It is as easy as it looks!
Old Jun 26, 2007 | 09:16 AM
Darkgh0st's Avatar
Darkgh0st
Cool. I finally found a project that I can handle then
Old Jun 26, 2007 | 09:39 AM
Mojave's Avatar
Mojave
On my 96, the coil was riveted on, which required drilling out the rivets. The new coil came with bolts so I could bolt it back on. YMMV.
Old Jun 26, 2007 | 09:59 AM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Just curious. Why are you replacing it?
Old Jun 26, 2007 | 10:04 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Once you get the PS reservoir outta' the way, it's a piece o' cake.
Be sure and wrap your coil wire in an 8" section of corrugated flexible tubing if yours is missing. You can buy it at auto parts stores.
It'll help minimize wire chaffing and help insulate the wire from the relentless underhood heat they're subjected to.
Old Jun 26, 2007 | 10:13 AM
Darkgh0st's Avatar
Darkgh0st
Still trying to fix a problem I'm having. If this doesnt work the Optispark is next. Problem happens only when its hot, so I'm thinking it might be a coil issue.
Old Jun 26, 2007 | 10:15 AM
Darkgh0st's Avatar
Darkgh0st
Damn, I gotta take that apart too?
I just had plugs and wires done and they did that. It didn't have the tubing on the wire before and it was arching like crazy before the wire was replaced.
Old Jun 26, 2007 | 10:24 AM
eschoendorff's Avatar
eschoendorff
St. Jude Donor '08
That corrugated wire shield is a great idea. The stuff's pretty cheap and has like 1000 other uses too. I generally keep about a 50' section of it on hand in the garage....
Old Jun 26, 2007 | 11:49 AM
zr1fred's Avatar
zr1fred
Did you change the ignition module (next to coil) , that's a more likely candidate. (got same problem on my 93).
Old Jun 26, 2007 | 11:51 AM
DougSilver's Avatar
DougSilver
I replaced the stock coil on my 95 with an MSD coil and it definitely ran better after the swap. As I recall, you will need a deep socket (9/16" maybe?) to get at one of the bolts or studs that holds the coil bracket to the head. I really took my time replacing and it took about an hour--the next time will take about 20 minutes. Also, make sure you apply the heat grease (or whatever it is called) on the coil mounting bracket. I'm sure others here will have a better step-by-step procedure but I recall dealing with the power steering bracket was a pita.
Doug
Old Jun 26, 2007 | 12:26 PM
Darkgh0st's Avatar
Darkgh0st
Doug
Thanks for the info
Old Jun 26, 2007 | 02:38 PM
pcolt94's Avatar
pcolt94
This is the hardest part. The original bracket has to be reused. It is best to grind the heads of the rivets off to get the studs out. Then just use the new hardware and mount.
But before you do this, you can electrically connect the coil with out removing the old coil. Just un-plug the connector and coil wire and connect to new coil. All wires will reach and just let it hang for a test. You can drive it like that and see if it really is the coil before you do a full installation.
Old Jun 26, 2007 | 03:36 PM
Darkgh0st's Avatar
Darkgh0st
I thought about doing that but I wasnt sure if it needed to be touching the block for grounding or something. I'll give it a shot
Old Jun 26, 2007 | 09:11 PM
Darkgh0st's Avatar
Darkgh0st
I talked to a gearhead at work and he said that it's really not a good idea to install the coil without grounding it. I guess I'm gonna haveta do a full install to see if that fixes my problem.
Old Jun 26, 2007 | 09:55 PM
Carpenter's Avatar
Carpenter
Listen to ZR-1 fred's advice please.
The LT1 coil is not 'known' to fail in heat. The ICM (ignition control module) IS.
The ICM is 'likely' your (heat related) problem. Very common problem.
FYI>>>If the ICM ends up needing replacement, it's VERY important to utilize the HEAT GREASE (as a heat sink conduit).
Another tip I used was installing the coil/icm bracket AWAY from the cyl. head using 3 flat washers on each bolt. Makes sense, being that it creates an air gap between the head and coil/icm bracket. As we all know....electronics HATE heat.
Old Jun 26, 2007 | 10:47 PM
Darkgh0st's Avatar
Darkgh0st
Good stuff man I will replace that too. Thanks
To How hard to replace LT1 Coil?
Darkgh0st's Avatar
Darkgh0st
Thanks for the info
Old Jun 27, 2007 | 07:26 AM
69mako's Avatar
69mako
It's a 1 beer job also don't forget to check your EGR valve for vacuum. If your having stumbling problems once the car warms up that could be a source
Old Jun 27, 2007 | 08:19 AM
onedef92's Avatar
onedef92
So true. But, if your ICM goes ****-up, there's a very likely chance it'll take your coil with it. That's what happened to me.
Oh, and for future reference. You'll come to know there's little "simple" about working on LT1 engines. Even with the clamshell hood, basic tune-up stuff like plugs and ignition wire swaps can be "challenging" at best.
Er, yeah, that's the word I'm looking for....
