Question about ring gaps
Old Jul 1, 2007 | 09:16 AM
96lt4c4's Avatar
96lt4c4
Default Question about ring gaps
I am getting ready to start filing the rings for my 383 LT4. I am running Mahle pistons and rings. I thought about going ahead and opening them up just a little more in case I want to run a 100 shot in the next year or 2. This is with a 4.029" bore.
Their recommendations
Street Strip
Top ring - Bore X .0045" = .018"
Second Ring - Bore X .0055" = .022"
Nitrous to 150 HP
Top ring - Bore X .0060" = .024"
Second Ring - Bore X .007" = .028"
It just seems like a big jump in size. Would I be sacrificing any power running the Nitrous gap for a while?
Old Jul 1, 2007 | 09:19 AM
Pete K's Avatar
Pete K
Street Strip
Nitrous to 150 HP
The blowby and power loss from the slightly higher ring gap is absolutely minimal. You have no choice. You must go with the bigger gaps.It will be fine though.
Old Jul 1, 2007 | 09:23 AM
96lt4c4's Avatar
96lt4c4
Thanks Pete, that makes me feel better
Old Jul 1, 2007 | 01:15 PM
JAKE's Avatar
JAKE
What's MOST important is never run the risk of the ring ends butting.
Jake
Old Jul 1, 2007 | 02:12 PM
edcmat-l1's Avatar
edcmat-l1
Better too wide than too tight......
Old Jul 1, 2007 | 02:15 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Jake
Alway err on the side of a little more than not enough gap.
Well, with rings anyway......
Old Jul 1, 2007 | 02:38 PM
pr0zac's Avatar
pr0zac
i filed my rings for nitrous on my 94 trans am and i think it is one of the best running engines i have ever put together.. and i am probably never going to get the chance to spray it.
Old Jul 1, 2007 | 02:48 PM
JackDidley's Avatar
JackDidley
Somebody has a dirty mind, but .
Old Jul 1, 2007 | 02:52 PM
JackDidley's Avatar
JackDidley
http://kb-silvolite.com/feature.php?action=read&F_id=62
Some good info on the topic here.
Old Jul 1, 2007 | 03:11 PM
Corvette Kid
Wha? There ya' go, casting aspersions at me again....
Great site and a frequent reference for me. Lots of handy info there.
Old Jul 1, 2007 | 04:12 PM
Greg Gore's Avatar
Greg Gore
Go with the .024/ .028 gaps recommended. The increase in blowby would be nill; you would have difficulty measuring it. Do spend a little time carefully deburring them afterwards. Measure your ring ends with a micrometer to be sure you have removed the burrs. When ring ends are ground or filed it raises a burr along the trailing edge which will prevent the ring from sealing against the ring land in the piston. Of more significance is your choice of top ring, the quality of the pistons and thus the quality of the top ring lands and the straightness and roundness of your honed bores. It is absolutely imperitive for any performance small block buildup to use honing plates while finish honing the bores. Not using them would be a much greater source of blowby than just about anything else. The quality of your work and exactness of your measurements in machining and preparing components for the shortblock is the foundation of any engine build and will determine the success of the job.
Old Jul 1, 2007 | 04:39 PM
Corvette Kid
I couldn't agree more. There's an old saying I remember from back in my oval racing days. It's called "The Five Ps." Prior Preparation Prevents Poor Performance.
Old Jul 2, 2007 | 08:09 AM
96lt4c4's Avatar
96lt4c4
I am sanding the burrs off the rings with 400 grit sand paper, and rounding off the sharp edges to keep from scratching the bore. I do have a micrometer and will go back and check them though. I am pretty confident in the quality of the pistons and the rings, all MAHLE parts. The block was honed with the torque plate installed. I am taking my time and double checking everything.
Old Jan 18, 2008 | 05:48 PM
Calderone's Avatar
Calderone
what's the difference if its honed without the torque plate ?
Old Jan 18, 2008 | 06:53 PM
cv67's Avatar
cv67
St. Jude Donor '05
On the rins make sure they are right side up and spaced properly. Found that out the hard way once.
Old Jan 18, 2008 | 06:55 PM
cv67's Avatar
cv67
St. Jude Donor '05
Using a torque plate simulates a block with heads torqued into place. More accurate.
Old Jan 18, 2008 | 08:26 PM
redrose's Avatar
redrose
sandpaper will cut the ends but leave a ''hump'' in between...use a ''whetstone'' (typ used to sharpen knives) as it ''finds'' the high spots.
To Question about ring gaps
Old Jan 19, 2008 | 03:46 PM
Calderone's Avatar
Calderone
thanx for the reply
i have a doubt
i got coated hypereuctectic mahle pistons
will bore .30 over and the rings will be '.0065" gap
is that right ?
Old Jan 19, 2008 | 05:17 PM
Tom Piper's Avatar
Tom Piper
I've often wondered if the factory used torque plates when honing the stock engine.
Anyone know?
Tom Piper
Old Jan 20, 2008 | 11:25 PM
rklessdriver's Avatar
rklessdriver
Anyone know?
Tom Piper
Tom,
About 8-10yrs ago we had a deal modifying ZZ3 and 454 HO crate engines for an air boat builder in Fla.
They were round with out the plate from GM.
Will
