Injector Recommendations
Old Jul 3, 2007 | 09:59 AM
geezel's Avatar
geezel
Default Injector Recommendations
I'm in the middle of a Super Ram install. Alvin at pcmforless is burning a chip and I've asked for his recommendation but I thought I'd ask you guys what FMS injectors I should use. 86 Vette with stock cubes, Super Ram, headers, exhaust, TPIS Big Mouth, TPIS 700-135 cam (224/224, .495/.495), TPIS heads (AFR 190, 54cc, 272 @ .500). My stock injector set had a couple of leakers so I'm presently running FMS 22# (pink tops). I still have the stock injectors.
Old Jul 3, 2007 | 10:13 AM
JAKE's Avatar
JAKE
I recently had the same question about injectors for the new engine I was building. I emailed Bryan at PCMFORLESS and he recommended which ones to buy for my specific combination.
Bryan burned my new PCM programming so I took his advice and recommendation and bought the injectors he recommended.
Since he was the one who was re-programming my PCM , taking his advice was a no-brainer.
Jake
Old Jul 3, 2007 | 10:03 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
If the pink tops are in good shape, why look for more ??
Old Jul 3, 2007 | 10:18 PM
geezel's Avatar
geezel
Alvin did reply and recommended the 24# blue tops. I just thought I'd get enough injector in while I had the intake off. Anyone interested in a low mileage set of pink tops?
Old Jul 3, 2007 | 11:11 PM
msslp04's Avatar
msslp04
St. Jude Donor '11,'14
How much for the pink tops? I am looking at replacing the injectors in my 89 coupe. Are these compatible???
Kevin
Old Jul 3, 2007 | 11:22 PM
AGENT 86's Avatar
AGENT 86
Kevin
Yes, and they work better when painted black.
Old Jul 3, 2007 | 11:25 PM
AGENT 86's Avatar
AGENT 86
Your setup will be very similar to mine. My injector duty cycle doesn't come close to maxing out, that's why I questioned the need to buy another set of injectors.
Old Jul 3, 2007 | 11:45 PM
geezel's Avatar
geezel
I'll take $200 shipped for the 22# injectors. I'll check Thursday for the mileage on them, but I believe it's around 5,000. (I know... should go to the for sale section.)
Old Jul 4, 2007 | 01:21 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
If your going to #24, you should get a AFR to regulate the fuel... but Pink tops work fine with my HSR/1.6RR/Headers/magaflow exhaust system, etc, etc.
Old Jul 4, 2007 | 02:16 AM
GRX's Avatar
GRX
Alvin did reply and recommended the 24# blue tops. I just thought I'd get enough injector in while I had the intake off. .........
To Injector Recommendations
