my 89 TPI runs rough when cold. it idles rough & hesitiates.
when it's warm, it runs great.
It has new injectors, new EGR, new PCV, new cap rotor, no codes.
Vacuum leaks! Mine ran rough and hunted for idle when in open loop (<140*) and settled out after it warmed up. There are a few different methods to check for vac leaks. Propane, WD-40, starting fluid, Seafoam, smoke in the intake. Basically, as soon as the O2 sensor starts sending voltage readings to the ECM the odd idling will stop. If not vac leaks, clean the TB and IAC, check voltage on the TPS, and Make sure the AIR system and MAF is operating correctly. Check the connections.
my 86 was doing that, and I changed the electronic spark control over by the heater, and it idles smooth now when cold. I also installed an adjustable pressure regulator and cranked up the pressure to 40 with the vacuum line on, and 45 without it.
other things to check are:
plug wires,
distributor cap,
the accordion inlet duct for leaks,
loose clamps on that duct,
cracked or broken vacuum hoses under the plenum,
loose connector on the map,
Egr valve,
timing,
partially plugged precats, or cat.
Coolant Temp Sensor is used in place of a choke and if yours is indicating the engine is warmed up, it'll be too lean when it's cold. Best to check with a scanner as it could also be a faulty ECM. You can buy another sensor and simply plug it into the harness. If it starts up and idles ok, R & R the old one. Other clues would be the fan running with it cold - a/c off; no fast idle.
screw it in to increase, out to decrease.
Remember, 89 was the first year they did away with the cold start injector, and reprogrammed the chip to increase fuel from the injectors when cold.
I would hazard a guess, that either the sensor (CTS) is sending erroneous info, or the engine has a weak ground, or there is a weak injector.
Also, to increase the fuel, the idle has to go up also. Check the IAC passages for restrictions. Also, when cold, the spark plug wire resistance changes. If there is a break in a plug wire, the core shrinks a little, causing extra gaps in the wire making the resistance really high.
Also, check for the proverbial cracked distributor cap, or a cap with lots of carbon tracking.
