Using the search function, I see that 16.0 is a typical/desired value. I think these injectors are originals. Should I be concerned with the low values? Or happy that all the values are relatively close?
Those numbers look great. The 16-17 ohms is mainly for the stock L98 injectors. The LT1 injectors ohm 12-13 ohms as you show. I would look in a different place for the problem, assuming the injectors are not leaking.
Those are good numbers. The injectors on my '93 are all ~13.2 ohms at cold.
There is no large change in any value. I also think that 12 ohms might be correct for that year of car. They are going to check a little higher when hot and a ½ ohm is fine. Besides, if an injector is leaking or not spraying right, resistance is not a direct indication of it. The earlier vettes had problems with injectors and when they went bad they measured much lower. The later years gave much less problems.
I would look else where for your problem. I would start with fuel pressure first and perhaps a fuel filter. You might even have some sort of ignition problem. You might check your codes on principal, but on this type of problem will probably show nothing.
I have good fuel pressure both idling and accelerating, based on the fuel gauge being taped to the window and car being driven. (Idle = 42, accelerating = 37-42). Would this rule out a bad fuel filter?
No codes are being thrown.
It's possible this problem started when I went through a car wash which included a underside wash, but I am not sure. Can you suggest other places I should look and/or other tests to be performed?
If you don't know when the fuel filter was changed last, I would go ahead and put a new one on. Have you checked your spark plugs, they will give you some more info to go by. Usually a white tip will indicate a lean condition on that cylinder. That could be a clogged injector not spraying, a bad spark plug, or bad plug wire or connection. That would be my next place to look. The 94-96 is sequential fire injection where at the 85-93 is batch/bank fire injection.
Do you have an adjustable fuel pressure regualtor? The fuel pressure looks to be just a tad low. That could be contrubiting to the problem. If it's adjustable, you can try and dial the pressure up a little to see it that helps.
The 95 has a vented opti spark which helps with water evaporation. I reread and see that it started after a engine wash. It's difficult, but you can try and get a hairdryer pointed at the opti and help dry it out. If you can, check the plug wire connections as well.
Check the spark coming out of the coil and the spark to each plug.
Check for fuel pressure at the Schrader valve on the RH side of the fuel runners.
Check the fuses to the injectors and the injector ckt with a noid light. I had a blown fuse to one bank of injectors. The RH exaust manifold was cold because the injectors were not firing.
And check the coil wire on top of the opti where it comes thru the water pump. Its close in there and any moisture or insulation break down might cause it to ark. Take a good look when its dark and rev the engine a little.
