HELP with Computer !!!
Old Jul 7, 2007 | 08:31 AM
BIGBYRD1993's Avatar
BIGBYRD1993
Cruise-In XI, XII Veteran
NCM Lifetime Member & Ambassador
Default HELP with Computer !!!
I have a '93 and my Mechanic says the Computer is bad. GM does not make them anymore and I can't find one at any Dealership. I also can't understand , if I can find a used one , why it can't be installed in my car??? I was also told it could be rebuilt , but if the Chips are bad , I can't get them replaced either. They say that they aren't available. SO , What am I to do???
Old Jul 7, 2007 | 09:18 AM
geogolf's Avatar
geogolf
Default computer
first is he talking about the ecm or ccm ,the ecm is the computer that control the engine. and any ecm from a 93 will work the ccm is what controls stuff like vats interior lights theft etc, if you are sure he knows what he doing might find one on ebay. but there is a lot of things that can make you think the ecm is bad not much help but maybe someone will chime in geo. as far as the chip you can get a custom chip and it will work
Old Jul 7, 2007 | 10:34 AM
rick lambert's Avatar
rick lambert
I think you can get one at Autozone.
Old Jul 7, 2007 | 10:36 AM
toptechx6's Avatar
toptechx6
A couple of possibilities:
http://www.ecudirect.com/index.asp
http://cgi.ebay.com/ebaymotors/ws/eB...6863446&rd=1,1
You may also want to PM Kalister, I think he just went through this, good luck, let us know how you make out.
Old Jul 7, 2007 | 07:37 PM
gmccloe's Avatar
gmccloe
6th Gear
Ireplaced my computer on my 94 LT-1 ABOUT 4 months ago my mechinic found me a used one for $400 the dealer wanted $1800 if you need I can get you his number.What is the reason you need to replace it.
Old Jul 7, 2007 | 10:19 PM
BIGBYRD1993
It started with the 2nd trip I took after buying it. I would lose the Tach and speedometer , for couple seconds. Car would jerk and then take off. Service light would come on. This has happened each time car was driven. Then it quit completely on highway. Waited a couple minutes, started it and tach and engine would go from zero to off board and die. Mechanic said computer was shot.
Old Jul 7, 2007 | 11:49 PM
anesthes's Avatar
anesthes
Well, something is wrong for sure. It *could* be the BCM (body control module). It *could* be the ECM. (electronic control module i.e, the 'computer'). Or it could be another problem. I'd try a different mechanic first, one with experience with these cars. A dealer wouldn't hurt.
-- Joe
Old Jul 9, 2007 | 08:57 AM
BIGBYRD1993
Thanks, He does come recommended. Even from the Parts People.
To HELP with Computer !!!
