MSD! Inform me!
http://www.mpsracing.com/products/MSD/ig02n.htm
This mod is qouted from thirdgen.org:
"MSD Ignition Amplifier- This mod is a real good boost for getting that last 500-1000 rpm out of the TPI system a lot quicker than it can do stock. It also is a plug in deal if you buy the harness adapter. But it is a fairly large box, and requires finding an appropriate remote location somewhere inside the engine compartment. It's well worth the effort, however. "
L98`s.... the stock HEI system is fine to a little over 5,000 rpm with NA V8`s
as for MSD`s 6A/AL series boxes, IMO, they have an unacceptably high failure rate...
if you think you really need a CD ign. system, i would recomend the Crane HI-6 box. its digital, has switch adjustable rev limiter, and from personal experience, is a much higher quality piece, for about the same, or less money than the 6AL....
The one problem we have seen, is the chips for the rev limiter are sometimes off by a good bit. Change em a couple times and you usually find a good, accurate one.
What it is supposed to really do is instead of the plug sparking once, it will spark multiple times up to a certain rpm (I think 3000-3500 or so).
After that it is supposed to just put out a bigger spark. So I can see a little better gas mileage and the car running a little better.....until it breaks like mine did for no reason.
Maybe a better coil would be cheap easy. If that does anything either.
This, on the other hand, I wonder where all these failed boxes come from. I/we have installed literally dozens of 6ALs over the years, plus all the other cars we work on that already have them, and can only think of one, single box going bad over a period of 5 or 6 years. I personally know people with boxes older than that.
i dont know what to tell you, other than i have personally experienced at least 2 failures with them, and more failures with other people i know, than i care to count over the years...
yeah, i know you see more MSD 6A/AL`s out there than just about all others combined, but still, it it seems to me that about one out of four or so end up failing within a year or two.some were repaired by MSD, including one of mine, others were sent back marked "unrepairable"...
i know of at least four Crane boxes, all of which have at least a couple of years of regular service on them, including one i bought over 8 years ago, and still working on a friends car... failure free.
and the convienence of the rotary switches... beats the daylights out of those rpm modules, anyday....
i havent heard of any failures with MSD`s "Digital 6" series, but i only know of a few of them in use.
they are considerably more expensive than a comparable Crane HI-6 though...
Do they both come with a sticker?
In regards to the MSD digi.... Your experience is the complete opposite of mine.
Ive ran a MSD 6al for almost 4 years now with no issues...
I mounted it in the compartment behind the pass seat... It gets hot but I guess not hot enough to hurt it
Have seen and read about enough digi-box failures to warrant (IMO) avoiding them like a disease..
MSD 6al box, Blaster coil, 4 years old
MSD 8.5 wires 2 years
MSD opti been over a year with no issues...
Noticable improvments?
Well being over 4 years for the box , I cant really say I remember for sure, but I think it did idle smoother...Maybe its all in my head, I dunno
It was done at the same time as a tune up..... Well new plugs and wires anyway, I didnt mess with the cap & rotor.
I noticed a huge diffrence after bolting the MSD opti on.
Before install my car didnt run...... After install it fired right up.
Thats the biggest diffrnce I noticed..... Other than a new (now 4year old) sticker on the toolbox
If you use the MSD wires ,that is supose to cure the radio noise and not using the MSD wires can cause the box to fail.
I had a 6al reverse polarity and the ground became hot ,I was *** holes and elboes ripping wires out before it burnt up the whole car.
I do run msd 6al boxes in both cars even though they do fail from heat.
The boxes also fail from vibration.
