FPR gains?
Old Jul 10, 2007 | 02:33 AM
Phatoscar's Avatar
Phatoscar
Default FPR gains?
By installing a Fuel pressure regulator can I get some hp gains?
Old Jul 10, 2007 | 04:21 AM
RRT vette's Avatar
RRT vette
You will need an adjustable fuel pressure regulator. If you fine tune the fuel pressure, you will gain some hp (10 or less), as long as the rest of the fuel and igniton system is up to snuff.
Old Jul 10, 2007 | 05:08 AM
conv90's Avatar
conv90
I doubt.
Year of the car?
The right fuel pressure on a stock engine is the fuel pressure generated by the stock regualtor.
If you have some mods, requiring different fuel levels, turning the FPR in the right position can help finding the right tune needed by your modded engine.
-Beppe-
Old Jul 10, 2007 | 10:26 AM
Aardwolf's Avatar
Aardwolf
There might be a small gain depending on where the A/F is. Dyno or track testing would be needed.
Old Jul 10, 2007 | 07:50 PM
Phatoscar's Avatar
Phatoscar
Well its a 1986 with a small cam and forged pistons!
Old Jul 10, 2007 | 07:59 PM
Road Agent's Avatar
Road Agent
Originally Posted by conv90
I doubt.
Year of the car?
-Beppe-
Old Jul 10, 2007 | 09:27 PM
5abivt's Avatar
5abivt
On a stock car where the ecu compensates according to the o2 sensor NO, there will be no gains. On anything modified if there is a need for extra fuel then upping the fp will help. But adding a fuel pressure regulator is like like adding a nozzle to a garden hose and trying to get more flow when all it does is regulate it.
Old Jul 10, 2007 | 10:00 PM
Aardwolf's Avatar
Aardwolf
The o2 on these years is ignored at WOT. You can tune with an AFPR. The FPR goes to its full setting at WOT. Even a stock car can be tuned better but probably not much as the stock tune is pretty good. Going custom for each type of mod can bring gains.
Old Jul 10, 2007 | 10:56 PM
5abivt's Avatar
5abivt
Right you are. I forgot wot the o2s are ignored.
Old Jul 10, 2007 | 11:34 PM
tequilaboy's Avatar
tequilaboy
The BLM (long term fuel trim) is still honored even at WOT.
The mixture is no longer changing dynamically as a result of O2 feedback at WOT, but the mixture is indeed influenced by the BLM which is in-turn influenced by the O2 sensor.
The 02 sensor therefore does have an effect on WOT fueling. The mixture is still compensated by the historic blm data for the cells in question (typically cell 15).
Old Jul 10, 2007 | 11:50 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
You know I will be bugging you about WOT tuning soon
And yes, I do have a wideband.
Old Jul 10, 2007 | 11:55 PM
hippy's Avatar
hippy
If the car's A/F ratio is "on" you'll see nothing in terms of HP, if it's "off" you might catch a couple. When I say a couple I mean A COUPLE.
Old Jul 11, 2007 | 12:11 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
It's not a great HP mod.
Phatoscar's Avatar
Phatoscar
thanks!
To FPR gains?
