Is this supposed to look like this?
Old 07-12-2007, 01:42 PM
69mako
69mako's Avatar
Originally Posted by CentralCoaster
Looks tasty.
Too phuckin funny
Old 07-12-2007, 01:49 PM
Steve85
Steve85's Avatar
Cruise-In V Veteran
A 95...that's right before dex-cool..perhaps that is some universal experimental all-in-one prototype engine fluid that led to the development of the long life fluid.
No doubt hushed by the oil companies because it allows the car to get 78MPG and requires no oil, and no maintenance. The fact that there was no knock is irrefutable proof of this unique find.
Put it on eBay.
Old 07-12-2007, 08:44 PM
Smooth
Smooth's Avatar
Default I f you didn't tell us...
I have sworn it was out of a mud bogger or at least dredged up from the depths of Lochness!!
Old 07-12-2007, 09:55 PM
Kinkajou
Kinkajou's Avatar
How does the coolant look?
Is there a mix of oil and coolant?
Old 07-12-2007, 10:18 PM
crossfire7
crossfire7's Avatar
Looks just like something I deposited in the lavatory today.
Good luck with that !
Old 07-12-2007, 11:27 PM
Repzard
Repzard's Avatar
You need to go on a fiber diet
Old 07-13-2007, 12:12 AM
Jeffvette
Jeffvette's Avatar
Location: No more yankee my wankee, the Donger is tired!
The coolant in the block and in the radiator was still a nice green. The oil however was (As CC put it) like nestle quick.
The driver side head was the culprit. It blew out the gasket on cylinder #7. The driver side head also had a small crack in the combustion chamber. Passenger side head and gasket were fine when I removed them.
New lifters are in, new gaskets are on, about to get another set of heads. And then everything else will follow. I'm removing the EGR, the air injection garbage. I will be replacing the WP and the opti as well.
Quick Reply: Is this supposed to look like this?
