Distributor gear in zz4?
Old 07-12-2007, 08:49 PM
85WHITEZ51
85WHITEZ51's Avatar
Default Distributor gear in zz4?
Will the factory distributor gear be OK with the ZZ4 enginge? Wasn't sure if I had to change the gear or if I could use the stock one.
Old 07-13-2007, 12:38 AM
etown brawler
etown brawler's Avatar
yes you can use the stock gear no problem
Old 07-14-2007, 02:50 PM
bent
bent's Avatar
I used the factory dist. gear off of my '88 distributor when I did the ZZ4 swap. within a few months I was pulling the distributor to change the gear because there were no teeth left on the gear! It is designed for a roller cam but the metalurgy is somehow different-- use the one that comes with the ZZ4 motor and install it on your distributor or order it from GM if you just got the short block. You don't want all of those metal shavings floating around your new engine!!
Old 07-14-2007, 03:45 PM
DrEvil11417
DrEvil11417's Avatar
do you remember which distributor gear you used?
Old 07-14-2007, 05:23 PM
etown brawler
a melonized distributor gear is not a different material then a stock gear.melonizing is just a surface treatment that aids in cam/dist gear break in by retaining lube .the melonizing wears off after break in . i always use a new gear with a new cam ,i only use g.m melonized gears .but if you use a normal gear you just got to make sure you use some good assembly lube when you drop it in.
Old 07-16-2007, 02:49 AM
bent
bent's Avatar
I should clarify. About 10 years ago, when my father (the mechanic) and I installed the ZZ4 crate engine into my 88 vette, we pulled the distributor out of the original engine and stabbed it into the ZZ4 without any changes. THIS WAS THE WRONG THING TO DO. The two metals weren't compatable and the motor eventually quit running due to the teeth being worn off of the distributor gear. If anyone doing this swap wants to use their stock distributor, the gear must be changed out. I do think I remember hearing the word "mellanized" somewhere along the way.
I hope you got the right gear on there-- white85 -- if not change it now
Old 07-16-2007, 07:59 PM
85WHITEZ51
85WHITEZ51's Avatar
Thanks Bent. I haven't dropped the distributor in yet so I'll just change the gear. Not worth the risk. I figure what's another couple of buck on a $6K project.
To Distributor gear in zz4?
Quick Reply: Distributor gear in zz4?
