85 Vette Fuel Pump
Old Jul 12, 2007 | 10:52 PM
Car Freak's Avatar
Car Freak
Cruising
Default 85 Vette Fuel Pump
Hi all! I posted here for the first time almost 7 months ago but can't find thread? Car still isn't running but at least it cranks now because that was one of the two problems! My carpenter an x-stereo alarm guy figured it out in 10 minutes, something to do with the alarm! I think I have the other problem of not starting is faulty fuel pump! Don't hear it turn on when the key is first turned? A friend put his finger on the schrader valve and said yes there is fuel in there but he thought it should shoot out rather then seep out and he believes the fuel presssure should be about 40 pounds? So my question now is, do you have to pull the tank to replace pump?
Thanks in advance!
Car Freak or was that Car Fool for having too many cars? lol!!!
Old Jul 12, 2007 | 11:16 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
You don't have to pull the tank, take off the fuel door by lifting it up and removing the screws under it. With that out of the way you will see a rubber boot, CAREFULLY take it out. It tears easily so be careful. Once the boot is out you can see the tank and all you have to do is take the screws out around the perimeter of the cover you see, remove the hoses noting where they came from for replacement. Just lift up on the cover and the fuel pump will come with it. Don't forget to replace the sock too. By far the easiest fuel pump R&R you will ever do.
Old Jul 13, 2007 | 12:26 AM
John A. Marker's Avatar
John A. Marker
....easy to replace. Took me about 1/2 hour. Pay attention to which way the sock is on the pump and which way it is located in the tank.
Fuel pressure for an 85 should be 36-40 PSI with the vacuum line to the fuel pressure regulator disconnected and plugged.
Old Jul 13, 2007 | 09:32 AM
Car Freak's Avatar
Car Freak
Cruising
Originally Posted by Midnight 85
You don't have to pull the tank, take off the fuel door by lifting it up .
Thanks guys! Good news for a change! One little question, are you saying that I don't have to remove fuel door, just lift it up and I will have enough clearance to get the rest out?
Old Jul 13, 2007 | 09:34 AM
Car Freak's Avatar
Car Freak
Cruising
When you say replace, do you mean with a new sock or the existing one? Thanks again!
Old Jul 13, 2007 | 09:42 AM
rons85's Avatar
rons85
when you open the fuel door you can see four small screws ( same as interior trim screws), in the corners of the base, that hold down the door and base assembly. Take out those four screws and the door/base will lift straight up and off. Now you can pry out the rubber boot. Then all is revealed...
The sock at the end of the pump Should come with the new pump - just make sure it's aligned the same way as the old one. You have to press the sock onto the end of the pump after you stick the pump onto the sender assy. It's also cheap insurance to replace the Pulsator (the connecting link between the pump itself and the line on the sending unit assembly) while you are in there... That is something you have to buy separately.
Oh - also not a bad idea to get a new Gasket for the sender assy when you buy the pump (it Won't come with the pump..). This is the square-ish shape gasket between the sender assy and the tank itself. You may be able to re-use the old one OK, or not..
Old Jul 13, 2007 | 10:26 AM
Car Freak's Avatar
Car Freak
Cruising
Thanks Rons85!
Old Jul 13, 2007 | 10:29 AM
CFI-EFI's Avatar
CFI-EFI
Don't just throw money at it. Diagnose and confirm that the pump is bad before you replace it. It is difficult to translate the length of the squirt out of the Schrader valve into psi. Check your fuel pressure with a gauge. You say you don't hear the pump run when you turn the key. You DO know that the pump is only supposed to run for about 2 seconds when you turn the key, right? Is there power to the pump? Is the fuse good? Is the fuel pump relay, relaying? How is the fuel filter?
RACE ON!!!
Old Jul 13, 2007 | 04:09 PM
FrankCandid's Avatar
FrankCandid
Please excuse the mild hijack.
Is the "Pulsator" the rectangular plastic piece with the 3 wires coming out of the top and bottom?
If so, I'd appreciate it if someone let me know where can I get one as well as a complete sending unit - they seem to be discontinued at AC Delco Canada.
Thanks.
Old Jul 13, 2007 | 04:14 PM
engle1147's Avatar
engle1147
This is a picture of pulsator: (top piece)
Old Jul 13, 2007 | 04:22 PM
FrankCandid
Man that was fast!
Thank you, sir!
I'd better start a new thread for my questions.
Old Jul 15, 2007 | 10:06 AM
Car Freak's Avatar
Car Freak
Cruising
RACE ON!!!
Hi! I replaced the fuel filter! Is the fuel pump relay easier to replace then the pump itself and where exactly is it? I also checked fuses and they look to be good. Thanks
Old Jul 15, 2007 | 10:49 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default relay
Fuel pump relay is at the back of the left rocker cover on the firewall. just unclip the wire harness connector, and remove the two screws that hold it to the firewall. a 1/4" ratchet, a 9/32 socket with a universal and extension gets it good
Old Jul 15, 2007 | 11:01 AM
Car Freak's Avatar
Car Freak
Cruising
Thanks! Nice avatar! What color is that 85? charcoal?
Old Jul 15, 2007 | 11:40 AM
CFI-EFI's Avatar
CFI-EFI
Unbelievable. It isn't an either/or situation. You don't replace the easiest one to get to. You trouble shoot to determine what the problem is, and then you fix or replace the cause. Your FSM has a trouble shooting chart just for this problem, if you can't reason your way through it.
RACE ON!!!
Old Jul 15, 2007 | 11:57 AM
Car Freak's Avatar
Car Freak
Cruising
RACE ON!!!
I don't have all the necessary tools and it beats having it towed to the dealer! I do have a gauge to check cylinder compression but I don't think I can use it for this application?
To 85 Vette Fuel Pump
