Changing a FPR on a 20 year old car is not necessarily throwing parts at it. While not a maintainance part, it probably should be. But I agree, "easter egging" parts is expensive and not very wise.
Well all, I'm happy to report that all is good, it was that darn Oring which connects the cold start valve to the runner, it's now starting up first time every time. I want to thank everyone for thier input esspecially CFI.
I'm glad it's fixed. Too bad you may have wasted money on fuel injectors. Any time you buy parts with your fingers crossed, you are throwing money at it. You can "maintenance justify" yourself into a complete new car...One Piece at a Time (with apologies to Johnny Cash).
Just a question I'm not able to find an answer to. Does the fuel system on an 86 have a check vavle to maintain pressure between starts?
Ok, finally got that fuel issue good, at least I thought but yesterday I drove it over to Walmart and back and decided to stop and have some lunch ansd wgen I got back in the car it started and when I put it in gear and started rolling back it died. Starts but won't idle, lots of popping from the throttle body. Here's what I've done to try a diagnose this:
Checked fuel pressure good at 40 lbs
chacked distributor rotor - good
plugs for spark - good
fuel pump relay new
GM tester code 12 - no issues
Vacuum lines in good order
changed fuel injectors about three weeks ago (leaky injector)
checked fuses - good
Do you still get fuel pressure with the key on?
Does it hold for a bit?
Sounds like it's backfiring through the intake. Did you loosen the dist any when doing testing?
Have you disconnected the MAF to see if it will run on it's own?
What is the TPS set at?
The SES light on?
I have an 86e with the very same problem.
I checked the fuel pressure with a gauge, and the fuel was bleeding off right away. I removed the fuel pump from the tank, and changed the pulsator, and the sock. I changed the sock on the pump, and when I grasped it, prior to changing it, it crumbled like paper.
the pulsator is from a 90, and it was better for a while.
I changed the quantity sender to a 90, and reassembled it with a new ground wire, new gasket.
I changed the FP regulator because I thought it was that, I put a holley one on it.
it might soon have been that because the red silicone rubber was delaminating from the glass cloth of the diaphragm.
I changed the fuel pump relay because the prime fuel was not present after the 2 second prime sequence. I had power at the relay terminals.
I changed the injectors last year, I also changed the manifold, heads, runners, and plenum. it was an engine upgrade.
It still bled down.
The gauge seemed to fluctuate a lot at idle, and dipped below 40 psi when goosing the throttle.
UPDATE:
Changing the fuel pump has helped immensely. The car runs better, and the fuel doesn't seem to drain back to the tank.
After the pump change, the needle is steady at idle, and when the throttle is moved rapidly, the fuel pressure does not go down, but increases 2-3 psi, then rises to 45, then settles down at 39 PSI.
The cat seems to run cooler.
There is no hot hot hot smell coming from under the car.
The car idles smoother, and when the throttle is closed rapidly, the engine does not die.
When starting it cold, the starter cranks a little longer than an instant start, but no where near the full minute it ws doing before.
The acceleration is better as well.
OK, but my question is, did you pull the tank to change the pump out? I've seen some threads that mention something about being able to see the srea where the pump is by pulling the fuel door seal off? any validity to that? I was looking in the FSM and it a heck of the procedure to pull the tank! Any other suggestions out there?
The pump comes straight through the TOP of the tank. Remove the fuel door and rubber boot and you will see the bolts holding the pump/gauge sender unit to the tank. Remove hoses and wiring and carefully pull the unit out.
Thanks, what about the fuel thats in the tank, I would hate to have a problem there? Shall I drain the tank?
Check a different section of your FSM. You wouldn't look up how to pull the engine to change the spark plugs.
Once again, I have to preach not to throw money or parts at it. It is possible the check valve is causing the fuel system to lose pressure when you shut the engine off. Do you still have that problem? I didn't notice where you said you did since you fixed the leak at the cold start injector.
A leaky check valve won't make the engine die. When the engine is running, the fuel is all flowing OUT of the tank. The check valve only prevents the fuel from returning, when the pump is off. All your previous posts have indicated good fuel pressure. Before you throw money at a possibly unneeded fuel pump, TEST it. Put a pressure gauge on it and go for a drive.
RACE ON!!!
Rgr, Rgr I did test it and initially fixing the leak did help the starting but
last Thursday I stopped for lunch and came out that the car started then died, it won't idle and is popping through the throttle body. I had to tow the car back to the house (bout a mile luckly) Heres what I checked when I got it home:
Checked fuel pressure good at 40 lbs (still drains down in 3 seconds)
checked distributor rotor - good
fuel pump relay new
My fuel pressure dropped like a rock, it was the pulse damper above fuel pump that caused it. A piece of fuel injection hose and 2 clamps and now my pressure holds for hours.
Thanks, I'll check into that but first I gotta find out why it's not idling all of sudden
