RE: 86 Fuel system
Old Jul 17, 2007 | 08:53 PM
senorv47's Avatar
senorv47
Default RE: 86 Fuel system
Quote:
Originally Posted by senorv47
Just a question I'm not able to find an answer to. Does the fuel system on an 86 have a check vavle to maintain pressure between starts?
Ok, finally got that fuel issue good, at least I thought but yesterday I drove it over to Walmart and back and decided to stop and have some lunch ansd wgen I got back in the car it started and when I put it in gear and started rolling back it died. Starts but won't idle, lots of popping from the throttle body. Here's what I've done to try a diagnose this:
Checked fuel pressure good at 40 lbs
chacked distributor rotor - good
plugs for spark - good
fuel pump relay new
GM tester code 12 - no issues
Vacuum lines in good order
changed fuel injectors about three weeks ago (leaky injector)
checked fuses - good
So can anyone give me some insight on this issue
Thanks,
Manny
Update 6 August 2007:
Just an update that might help those members who are still having problems. I read somewhere the last couple of days about an oder that come from the car (finally got it started after replacing the fuel pump but still was not idling) like rotten eggs, well it point to the O2 sensor and guess what? That was part of the problem, after I change that then it idles but only with the MAF disconnected, so I still have an issue with the MAF but now at least I know what it is. Thanks to all who help on this thread. I think I can handle it now.
Old Jul 17, 2007 | 09:27 PM
Aardwolf's Avatar
Aardwolf
From what I remember yes but it is inside the fuel pump.
Old Jul 17, 2007 | 09:45 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
although I'm not sure it's a check valve per se. it will bleed down. The pump runs for about 50 sec. when the ignition key is turned on. You have to turn the key off for over 5 sec. to have it turn on again for 50 sec.
Old Jul 18, 2007 | 09:52 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Except for the 50 seconds, more like 2 seconds.
Old Jul 18, 2007 | 10:45 AM
CFI-EFI's Avatar
CFI-EFI
Except for the 50 seconds, more like 2 seconds, and except for the 5 seconds is more like 10 seconds.
BUT! A leaking or defective check valve isn't the only place fuel system pressure can bleed off. Pressure can be relieved from three different places. As you suspected, the check valve in the fuel pump, the least serious and least in need of repair, each of the 8 fuel injectors, and finally the fuel pressure regulator. I believe your FSM has the tests to isolate which of the three is your problem. The tests involve pinching the inlet and outlet fuel hoses while observing fuel pressure. You will also find the procedures if you do a search. The tests have been written up many times, including several by myself.
RACE ON!!!
Old Jul 18, 2007 | 02:13 PM
senorv47's Avatar
senorv47
RACE ON!!!
Thanks dude, I appreciate everyone input on this. I just changed out the injectors and the problem got alittle better but there is still a pressure issue somewhere. I have to crank it at least twice before it will start whether cold or hot By the way it's an 86 Corvette
Old Jul 18, 2007 | 02:24 PM
zr1fred's Avatar
zr1fred
If it hasn't been changed, the fuel pressure regulator might be a good place to start, it's just a rubber diaphram, and they go bad, and they are pretty cheap.
Old Jul 18, 2007 | 03:17 PM
AGENT 86's Avatar
AGENT 86
If you don't have a fuel pressure gauge, buy or borrow one. My fuel pressure loss was at the pulse damper above fuel pump.
http://members.shaw.ca/corvette86/Fu...mDiagnosis.pdf
Old Jul 18, 2007 | 03:19 PM
mikey whipreck's Avatar
mikey whipreck
Mine too
Old Jul 18, 2007 | 06:52 PM
CFI-EFI's Avatar
CFI-EFI
Yes, but don't replace anything until you do the tests and discover a defective part. Throwing money at a problem only wastes your hard earned. If you have money to burn, take it to the stealership.
Dude??? Hey Bubba, according to this, I don't see where you have even checked the fuel pressure. Extended cranking can have multiple causes. Have you checked the pressure before touching the car after letting it sit? What happens to the pressure when you turn the ignition to "On"? When cranking. If they bleed down, how long does it take? Is the priming function working? A little trouble shooting can save a lot of money. I hope you had good cause for changing those injectors.
RACE ON!!!
Old Jul 18, 2007 | 07:40 PM
senorv47's Avatar
senorv47
RACE ON!!!
Apologize for the Dude thing, just a friendly Maryland thing, anyhow, I took it to a mechanic for diagnosis and they tell me and documented that the fuel pressure was good and the fuel pump was good (haven't tested it myself) and that I had one or two leaky fuel injectors. They wanted to charge me $1400.00 (which included all the injectors plus labor) to fix it but I found some injectors from a fellow forum member and they ohmed out good and so I did the work myself. I replaced all the O rings and caps on the injectors,then replaced the O-rings on the fuel rail, and gaskets on the runners. So while the problem did get better (only have to crank two times versus five, but sometimes it cranks the first time) the problem still exists. I'm going to buy my own pressure tester and follow the FSM procedures and see what happens.
I do however appreciate all the feedback because it gives me a warm and fuzzy that I have my fellow experienced forum member to help me. If there are any other helpful hints out there, I would be welcomed to hear them. Thanks again guys and gal's great feedback!!
Old Jul 18, 2007 | 09:10 PM
senorv47's Avatar
senorv47
ttt Any other comments?
Old Jul 19, 2007 | 01:13 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
What comments are you looking for:
If you follow the pressure test, then get back with the results, there might be addl comments or help, but you'll need to continue the process.... first...
Old Jul 19, 2007 | 06:45 AM
senorv47's Avatar
senorv47
I mean't helpful tips as I continue the tests
Old Jul 19, 2007 | 10:41 AM
CFI-EFI's Avatar
CFI-EFI
Yes. Do the tests. Start as redirected, below, to see if you even have a leak down problem. Once we get those results, we can proceed from there.
Extended cranking can have multiple causes. Have you checked the pressure before touching the car after letting it sit? What happens to the pressure when you turn the ignition to "On"? When cranking. If it bleeds down, how long does it take? Is the priming function working?
RACE ON!!!.
Old Jul 21, 2007 | 02:40 PM
senorv47's Avatar
senorv47
RACE ON!!!.
Did the test, with out touching the car I have 0 pressure. When I turn the key on I get 42 lbs and bleed down occurs 2 seconds later. with the car running I get a consistent 38 lbs of pressure to the rail. Any further thoughts?
Old Jul 21, 2007 | 03:59 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default fuel
I have an 86e with the very same problem.
I checked the fuel pressure with a gauge, and the fuel was bleeding off right away. I removed the fuel pump from the tank, and changed the pulsator, and the sock. I changed the sock on the pump, and when I grasped it, prior to changing it, it crumbled like paper.
the pulsator is from a 90, and it was better for a while.
I changed the quantity sender to a 90, and reassembled it with a new ground wire, new gasket.
I changed the FP regulator because I thought it was that, I put a holley one on it.
it might soon have been that because the red silicone rubber was delaminating from the glass cloth of the diaphragm.
I changed the fuel pump relay because the prime fuel was not present after the 2 second prime sequence. I had power at the relay terminals.
I changed the injectors last year, I also changed the manifold, heads, runners, and plenum. it was an engine upgrade.
It still bled down.
The gauge seemed to fluctuate a lot at idle, and dipped below 40 psi when goosing the throttle.
UPDATE:
Changing the fuel pump has helped immensely. The car runs better, and the fuel doesn't seem to drain back to the tank.
After the pump change, the needle is steady at idle, and when the throttle is moved rapidly, the fuel pressure does not go down, but increases 2-3 psi, then rises to 45, then settles down at 39 PSI.
The cat seems to run cooler.
There is no hot hot hot smell coming from under the car.
The car idles smoother, and when the throttle is closed rapidly, the engine does not die.
When starting it cold, the starter cranks a little longer than an instant start, but no where near the full minute it ws doing before.
The acceleration is better as well.
To RE: 86 Fuel system
Old Jul 21, 2007 | 05:57 PM
CFI-EFI's Avatar
CFI-EFI
Just keep throwing parts at it.
Cut and pasted from my PMs so the rest of the forum would be aware of what he had been advised.
RACE ON!!!
Thanks,
Manny
OK. Good starting info. The fuel pump and the fuel pump relay both work. The fuel pump relay was one possibility for extended cranking times. Total bleed down in 2 seconds is drastic. There are only three places the pressure can bleed off with out making a mess on the garage floor. 1.) The fuel pump check valve, 2.) The injectors, and 3.) The fuel pressure regulator. Follow the test procedures in your FSM or from the archives of the forum to determine which of the three is leaking. The tests consist of pinching off the feed and return fuel lines under different conditions to tell you where the leak is. I, myself, have posted the procedures a couple of times. Let me know what you find.
RACE ON!!!
Old Jul 21, 2007 | 07:00 PM
senorv47's Avatar
senorv47
RACE ON!!!
CFI, I did find a leak where the cold start injector goes into the fuel rail and I think I've got that taken care of. I will report more when I get home this evening.
Old Jul 21, 2007 | 07:32 PM
zr1fred's Avatar
zr1fred
Changing a FPR on a 20 year old car is not necessarily throwing parts at it. While not a maintainance part, it probably should be. But I agree, "easter egging" parts is expensive and not very wise.
