Hard brake pedal solution, finally!!
Da Mail Man - we both have 88's and my brakes used to be adequate, but not exceptional. The pads were new when I bought the vette, I don't know the brand.
I replaced the pads a few months ago with EBC Greenstuff, and now have 'Fred Flintstone' brakes.
I have 2 problems -
1. These pads only work when they're very hot, and I can't keep them up to temperature. The strange thing is that sometimes when they are cold they work a bit and occasionally it's as if they're very wet and two feet on the brake pedal still won't stop the car quickly, especially driving slowly round town. I'm going to replace the pads with what I had before, if I can find out what they were - I still have them.
2. I have an extremely intermittent problem where I have occasionally hit the brakes and the pedal has gone down a long way, like I've lost all my fluid, very scary, I've immediately pumped it once or twice and it's come back up. No signs of fluid loss. My vette is a daily driver and last occurence was before Christmas - v weird.
About three years ago I had the brake bias spring fitted. At the time the brakes were OK, but not as good as a 'normal' car and I thought the rears didn't seem to be doing much - not much dust there and on gravel the fronts lock up and the rears don't. The spring made no difference that I could tell.
From re reading this thread, and my own observations, I think that the composition of the pad makes a difference and that there is something stopping the rear brakes from working like they did out of the factory.
If so, I think it's either the calipers or the ABS.
Badabing9 has suggested, from his own experience, that
SunCR tells me he has never changed the fluid in his 1989, since it was new and his brakes are fine. Which suggests that it's letting air into the system, from fitting new parts, that starts the problem, and surely that points to air in the ABS?
I have 2 problems -
So I'm considering re-building the rear calipers and changing to better pads. If I'm not back to the level of braking I used to have, I will then disconnect the ABS and hope that will be the answer.
I had a code 71 so I pulled the EBCM, made sure the connections were clean, put it back in and cleared the codes. Still have the problem but no codes are present. "sys" is flashing on the speedometer screen. Replacing the EBCM is a last resort since it's so expensive. Are there any other things to try??
I believe this information is good for 92-94, possibly 95, and not sure about 96 since it is OBDII.
I’m not arguing with success, but a code is an indication of a fault or problem. The code can always be cleared but if the problem is not fixed, the code will be reset. The code is used to lead you to a problem area so the trouble can be repaired. So I don’t understand how clearing a code can make a brake system or for that mater, anything work better as if it was repaired.
I would need a real good technical explanation, that would be believable to me. Like the valves in the pump were restricting fluid flow with out the pump running. Pulling the fuse or power to it should disable any solenoid action in the ABS pump.
I happen to know the guys at Corvette Masters and they are a knowledgeable group also that helped me out once and have spoke with on several occasions. They use a tech 2 which they probably used to clear the codes.
I sure would like to hear the rest of the story if there is one.
I bought a 95 triple black in January with 30 K on it.I agree,the brakes suck.I've read most of this thread and am wondering where to start.
In the old days on my 65 conv. chevelle,when the brakes acted like this it was usually the inside of the rubber lines to the brakes coming from the body,that were collapsing on the inside.Change the lines and brakes again.Same thing on my old chevy work vans and my brothers chevelle.
Yet,I've not read anything in this thread about anybody changing the rubber lines.Are they so good now that this is not an issue?
I'm considering starting there just because of the age.Am I wasting my time and money?
The biggest difference I have found is with the Pads. Twice I've had 'performance' pads and they were useless until red hot.
Thanks to Da Mail Man I now have adequate brakes again, I fitted Brembo pads to the front. My rears don't seem to do much, I have the brake bias spring but it didn't seem to make any noticeable difference.
I fitted the s/s flexible lines a few years ago, when my brakes were adequate, didn't notice the difference but obviously they're a better thing to have.
I said most of the thread,not all of it.I knew I should have read more of it before I posted.
I push on the brakes and they just don't respond like disc brakes on other vehicles.It's about half as bad as trying to stop a car with power brakes when the engine is off.They do improve a bit after they heat up,however not what I assume Chevy meant them to be.When they are cold,I can stand on them and they don't fully respond.
Where is the best place to get the s/s lines?Also,what is the best place to start looking for the problem?
I took out the ABS fuse and it made no difference.
My vette is a I988 s/s brake lines, brake bias spring, all else standard.
In my last post, July 2008 I had just fitted Brembo pads to the front. The brakes were back to 'adequate' because the previous pads only worked when red hot (there were EBC Greenstuff)
The brakes were fine until recently when I replaced the rear EBC Greenstuff pads, which I'm sure were useless like the fronts were, with some standard Bendix pads. At the same time I fitted a new master cylinder with a new brake bias spring.
Once again my brakes are barely adequate, they feel 'greasy' and require more pedal pressure. The booster is working and there is no air in the system.
I plan to put the Gm spring back in the MC, because the bias spring seems to have removed braking power from the fronts.
I think I was mistaken to think that it would increase the rear brake power without lessening the fronts. It makes sense now, you can't get something for nothing, and I read in this thread today, on around page 11/12 that the bias spring is designed to rebalance the brakes when bigger rotors are fitted. So I've made a mistake.
I doubt the new rear pads have any influence on this, the EBC Greenstuff pads had to be red hot to work and the Bendix replacements are standard and used in many ordinary cars.
Like many vette owners, I don't think my rear brakes do much and when you see the tiny size of the pads, you wonder what the heck was GM thinking?
Anyone care to comment?
I recently replaced my wheels on my 86 with C5 thinspokes and some better tires.
I noticed, standing back looking at my new wheels, that the rear rotors were almost as large as the front ones in diameter. the difference only seems to be the size of the calipers and pads. I noticed how nice and polished the rear discs are, and how abused th front discs look. I just bought C5 calipers and rotors to increase the brakes to C5 stuff. I have a C5, and it stops perfect. It will throw you through the windshield.
I also am putting disc brakes on my 57 chevy truck, and I am using the serpentine belt system from a 86 corvette with the 86 power steering pump and a hydroboost.
I will eventually put the vette front end on it to compliment the L98 and 4+3 that is in it now. I am not using the 86 calipers and rotors now, i am using 65 chevy truck dual piston calipers with adapters and a proportioning valve and special rotors. I have the master cylinder and hydroboost from a 92 3/4 ton truck with line reducers to go from a 5/16" line to a 3/16 " line. Making the pedal/booster bracket now.
Doing it this gives you automatically set's up inside/outside for each caliper.
i have a tool (2) that i can screw into the bleeder screws that will register the brake pressure inside the calipers and lock them into a gauge reading. however, still haven't gotten around to it yet...ugh!...
....brakes 100% better then when i started....curious though what the pressures are in that, if the pressures are in the ball park, it would then be an issue of friction material i would believe.....
i dont believe this problem has anything to do with the brakes themselves
i think that the problem stems from the vacuum system
im thinking that there is a release of vacuum somewhere and the brake booster is not getting enough vacuum to pull the brakes hard enough
thus the need to maaaaash the hell out of the pedal to get it to stop
because i have had my car do this and i have had it NOT do it
so i have a condition where sometimes i can mash the brakes and it stops on a dime but sometimes ill mash em and be like hmmmm i hope i stop
so there
that is my hypothesis on what the real problem is
you guys are looking at the brake system
when its the vacuum system that is the problem
and as we all know chevy decided to make everything vacuum actuated in these cars
When cold they felt like they had grease on them and I had to use two feet on the brake pedal for emergencies. This was usually in slow city traffic. Once I had heated them up they worked better and when they were really abused and red hot, they were excellent.
Thought I'd mention that in case your symptoms also relate to the temperature of your brake pads.
Otherwise perhaps you have an intermittent vacuum leak.
so there
well i just got through tearing apart the vehicle and doing the brakes
**not sure i agree. i have rigged a spare vac tank of sorts made from a large diameter pvc heavy-wall pipe and a vac fitting and made sure that there was enough vacuum for the booster although, that sort of a set up would be for large cammed rides having problems attaining sufficient vacuum from their engines....i have check all over for vac leaks of any sort and found none..the vac booster hold vac even for a few days of non-use and i doubt that gm or the feds would allow a vehicle to leave the plant with insufficient breaking...
**see above...i am sure you have already checked for soft break lines, vac hoses, etc as well as the check valve...i wonder if anyone (since it has been a while since i read this post) have tried the exact same pads gm released the car from the factory with.
**could it be that maybe fluid is blowing past a seal in the calipers but NOT leaking fluid causing a loss of pressure?
so there that is my hypothesis on what the real problem is you guys are looking at the brake system when its the vacuum system that is the problem
**i don't fully agree!
[/I]
me too! ABS sucks.
