double clutching, does it help?
Old Aug 2, 2007 | 04:30 AM
  #41
willfromthehill's Avatar
willfromthehill
Double clutching increases the life of the synchros because your not using them. Yes synchros wear out. They're a mechanical device and all mechanical devices wear. But it also increases the life of you clutch. If your matching your speeds correctly the flywheel and the clutch should be going the same speed. So when they lock up there should be no slipping. By the way the ZF6 is a fully synchronized Transmission Which includes reverse.
