A/C problem or just me
Old Aug 2, 2007 | 01:58 PM
corvette8189's Avatar
corvette8189
Default A/C problem or just me
every time i turn on my A/C it takes a good 2 to 3 min. to start blowing. the vents at the feet start blowing right when i turn it on but the top ones dont. whats the problem or should it do that
Old Aug 2, 2007 | 02:46 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
What year Vette? Can't tell from the photo.
Old Aug 2, 2007 | 02:55 PM
SunCr's Avatar
SunCr
GM used a delay in later Years to keep the windshield from fogging over - usually with air directed or purged through the floor vents first.
Old Aug 2, 2007 | 03:47 PM
corvette8189
96 vert, auto
Old Aug 2, 2007 | 07:15 PM
SunCr's Avatar
SunCr
Check your Owner's Manual - I'm pretty sure it's normal though as these systems became more sophisticated, GM added certain activities/events based on signals/inputs from the inside/outside sensors along with the Coolant Temp Signal (such as no heat until the CTS indicated a coolant temp that wouldn't blow cold air through the heat vents). Purge function - to keep the windshield from fogging over before the system had dehumidified the air - has been around for quite some time. And as these things age, it wouldn't be unusal for something to take a little longer since the inputs are generated by decreasing resistance in the sensing device/voltage drop through the wiring.
To A/C problem or just me
