Todays Corvette Drama
So far this month I have installed... (on my 89 Vette)
Heddman Jet-Coated Street Headers
Full Length Magnaflow exhaust
Oxygen Pump Delete
EGR Delete
VKE Remote Keyless Entry
New Emergency Brake
Fixed the tailight bulb holder
Cruise Control
New Bosche O2 Sensor
and a few other Misc Parts
So, now for the problems I still have to fix, some of which I am beginning to think I caused...
Right around the time the O2 pump was deleted the idle began to bounce around when I come to a stop. For example... I am rolling down a hill in neutral and come to a stop. The car bounces from 700RMP to 500RPM almost stalls and then jumps to 900RPM and then Idles perfectly at 700 like it should. Does this every single time. I'm thinking something like idle air controller... do I even have one? What do you think...
Also, I had a buddy of mine set the fans down to turn on at 180*F. Worked perfectly until I did my recent mods. Now as soon as I turn the car on the fan kicks on????
Oh, and this problem is driving me nuts. I plan to do some engine work mid-winter, so for now I relocated the alternator inbetween where the O2 pump would have been and the Alt used to be. Well this dam thing keeps bending 1/4 in steel brackets. Does anyone have any pics or know where i can get a setup to mount the Alternator cleanly. I am not interested in the O2 pully junk.
Ok so what do you think of todays Issues?
DG
Now as far as the rise in rpm to 90-0, it sounds like that is like mine just after I start it, and it goes through the evap cannister purge.
you might be getting a cold start sequence because of a loose wire to the ecm or something from the cts.
it sounds like your car is flip flopping from open loop to closed loop
As for the vacuum leaks... I don't think its a vacuum leak,... when its in the driveway it idles just fine. Its only on startup and when I come to a stop while rolling in neutral.
DG
What two pins to I have to connect to throw codes or test the MIL. I have reason to believe it may have been connected.
DG
The top left pin is "A" (red)
The top right pin is "B" (black)
The bottom left pin is "C" (green)
The bottom left pin is "D" (yellow)
IAC test link:
http://content.madirect.com/pdf/601088.pdf
Oxygen Pump Delete
EGR Delete
New Emergency Brake
Cruise Control
DG
As for you not wanting to use a Air Pump delete pulley, look at what you have been experiencing "keeps bending 1/4" steel" .
I think you nailed it when you said
In the meanwhile I will attempt to check for codes
Hopefull the MIL is functional.
DG
They can be money pits. There was nothing wrong with mine, decided to check a thing or two in the name of preventative maintenance. One year and 3k later it started the other day. Still on stands, though.
The "while Im at its" are a **** to combat.
Same boat,... I don't know where you got the idea I have the money for this... you should see my bank statements. My problem is that I love my toys more than eating anything but soup for dinner. wanna hear whats wrong with mine? = My turn
power att dont work = broke that by mistake, caught a tree branch, lucky the exhaust plays music right?
i had to rig the lights in the dash to work{did a fine job too lol} = haven't had that problem yet
i gotta replace the rack soon,pinion seal is leaking. = god i hope that doesn't happen
mine dont idle right either = +1
i think i need to replace the timing chain = +1
its got bad grounds = Oh God, check my post about the keyless entry, someone was under my dash with an ax.
ac compresor wont kick on = +1 my seal is bad too
had to put a sensor on the rad to tell the fan to kick on = +1 and don't forget the PCM tune for the primary fanribbon on passenger side is broke = ????
needs carpet on the doors,thats it for the inside.and it needs a paintjob. = I have an illness that forces me to repaint an entire car due to various abrasions. i will never give up on this car. = don't worry, neither will I
i love driving this car.oh did i mention i need every piece of weather stripping replaced = +1 Love when it rains, I don't have to take a shower in the morning!!!
Hows your drivers seat,... mines broke ?
Welcome to my world....
DG
My A/C is disconnected....
Try that one tomorrow,
DG
rain huh? Im going to take alot of heat for this one
Picture was taken from my cell phone out of the 96 Impala,... Girlfriend in front driving the vette...
Be easy guys, storm caught us off guard on a trip, infact we had to get a room for the night at some sleezy hotel because the Impala kept getting stuck...go figure.
I don't mind working on it,... if I didn't have anything to do on it I would be bored anyway. It does get expensive though and always at the worst time....
DG
DG
