1991 Odometer Error
Old Aug 6, 2007 | 09:25 AM
CYCOPE's Avatar
CYCOPE
5th Gear
Default 1991 Odometer Error
Several Weeks Ago I Had To Use My Quick Start Setting Of My Battery Charger To Fire Off My 91 Due To A Battery Drain. When I Started My Corvette, Which Fired Right Up I Noticed That The Odometer Reading Quickly Changed From Milage To A "odo Error" Reading. I Tried Disconnecting The Battery After Shut-down For 30 Minutes And Reconnected The Battery But No Luck In A Reset. Over The Past Few Weeks With Help From A Friend We Changed Out The Cluster Gauge To See If I Had Fried It And Still Had The "odo Error." All The Other Systems Work Fine: Mpg, Miles Left On Remaining Fuel, Speed, Mph & Kilo, Etc.... We Also Tried A Different Drivers Information Display And Switch Assy. With No Luck.
Can Someone Out There Help Me In Getting My Odometer To Function Properly Again? The Milage Reset Button On The Drivers Information Switch Does Not Help By The Way....
Old Aug 6, 2007 | 10:12 AM
RRT vette's Avatar
RRT vette
The CCM is what stores the mileage. You can try and pull the CCM codes, but will need a FSM.
Old Aug 15, 2007 | 12:46 PM
CYCOPE's Avatar
CYCOPE
5th Gear
Problem Solved. Bad Ccm
Old Dec 5, 2017 | 09:23 PM
JBJrC4's Avatar
JBJrC4
I know this is old, but I'm experiencing the same problem. Can I ask where did you get the new CCM and who programmed it?
To 1991 Odometer Error
